mate it depends on how filthy it is i went thru a shitload almost 2 litres tryin to flush my clutch system
hey all, how much brake fluid should i buy in order to bleed a whole brake system and clutch system on ae86
well, a commodore uses bout 1litre to do the brakes.
id buy 2 litres and you should be right
suck all the fluid out of the resivoirs then top up with new stuff before you start bleeding them, also, wipe out the clutch master to get rid of all the crap, will make bleeding it much easier
