Results 1 to 10 of 19
Thread: How hot does your 4age need to get and for how long till its OVERHEATING?
    Nov 2005
    Hey ae86dc
    just wondering as the title states.
    Sep 2009
    Why dont you put what you want people to ask in the post?
    Ie : Title > 4age over heating issued
    Body : My car is over heating, what would be the cause. I am concerned.
    ECT
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    Check the basics yet?
    Radiator, clutch fan, hoses, water level
    i had the same problem as you. i found out is was my clutch fan was routed
    also does it only overheat in traffic or all the time?
    i'd say anything over 3/4 is bad
    depending age of engine, the gasket can blow at that, if ur lucky it can last 10 overheats. fix ur problem i reckon
    Senior Member quoccy's Avatar
    Peter
    <div class='quotetop'>QUOTE (Bobomacho @ Nov 19 2007, 09:46 PM) </div>
    what would u know, its not like your a mechanic
    Oldschool Member
    Jul 2006
    often an overheating engine is a SYMPTOM of a blown head gasket, not the other way around (unless there is a coolant leak).
    Take the radiator cap off and see if bubbles appear. Either that or take it to a radiator place where they will put a gauge on it which will tell you what it is most likely to be.
    Veteran blair's Avatar
    Blair
    SEQ
    my guage for my 4ac
    gets stuck on half way
    so as far as im concerned.
    its always running warm
    gunbz-r
    anythin over 95 degrees is dangerous in any car, most cars run at 88-92 degree op temp. in my experience a few times over 115 ur in trouble tho i drove the ae111 with no water in it from parra to cambelltown and it was fine lol, didnt like it tho
    Ryan
    qld
    brisbane
    Aust.
    <div class='quotetop'>QUOTE (winslow @ Nov 20 2007, 10:32 AM) </div>
    lol, mine doesnt go over 1/4 ... so in my case, its always nice and cool. yes, this also happends with constant thrashing.
    gunbz-r
    as for checkin head gaskets get a tk tester, dont try and diagnose it thru bublles int he radiator often can be a false symptom, if unavailabe check for carbon or oil in the coolant or custard in ur sump or under oil cap mmmm custard. also excessive water comin out of the exhaust
  1. 4age overheating
    By Sprinter Freak in forum Technical - Questions
    Last Post: 1st October 2012, 09:58 PM
  2. Overheating Smallport 4age AE71- Headgasket?
    By pauliee in forum Technical - Questions
    Last Post: 28th September 2012, 02:01 AM
  3. KE70 4AGE - Rego till Feb 2010 - Melb
    By jeff in forum Cars for Sale (Toyota Only)
    Last Post: 10th September 2009, 09:40 PM
  4. sr20det overheating issues (I KNOW ITS NOT A 4AGE)
    By Fozz in forum Technical - Questions
    Last Post: 22nd March 2009, 11:14 PM
  5. 4AGE overheating problem
    By shinny in forum Technical - Questions
    Last Post: 25th November 2007, 12:31 AM
