Results 1 to 10 of 20
Thread: Clutch questions ke70
    Oldschool Member
    Nov 2007
    Hi all. I have a KE70 that i am doing a silvertop conversion on, i have ordered a t50 jdm gearbx that i will be using. What clutch would fit this. I rang up Bursons today and also aussie brakes and they need to know more informtaion on it, for those of you who have dont the conversion can you please tell me what throwout bearing, clutch and what ever else you used and what there part numbers are or what the parts are. I need to know by tomorow so i can order the parts.
    Sheldon
    gunbz-r
    mate its just any 4a clutch with the rwd throw out bearing, im runnin a clutch for an ae92 and it works fine
    obviously it needs to match the flywheel u r using
    Oldschool Member
    Nov 2007
    Ohh cool.
    Will tell them that tomorow.
    What about heavier duty clutches. I want a cushion button clutch or maybe even button no cushion.
    gunbz-r
    pmd ya bud in regards to button clutch
    Oldschool Member
    Nov 2007
    Also whats the go with the standard pressure plate. Will it last with a brass button or should i get a new one. Just curious.
    gunbz-r
    yeh probly wouldn't be that bad, night not bite as hard not sure never done it, but would work,
    Ty
    ACT
    ACT
    I've got a 20V flywheel and 215mm clutch kit for a 7afe with ADM T50. Clutch is a exedy sports tuff 4puck sprung button, and slips like hell.
    Oldschool Member
    Nov 2007
    How old is your clutch.
    Ty
    ACT
    ACT
    <div class='quotetop'>QUOTE (sheldonmcg14 @ Nov 20 2007, 07:25 PM) </div>mine? was slipping from new, after 12,000km its still slipping.
    gunbz-r
    interesting, was it clean when it went together and is it an exedy p plate, thats rather unusual should of pulled it out and sent it to get checked bud might be manufacture fault
  1. clutch and motor questions
    By wanted_ae86 in forum Technical - Questions
    Last Post: 29th April 2012, 08:58 AM
  2. Clutch/gearbox questions
    By Bozu in forum Technical - Questions
    Last Post: 22nd August 2011, 04:35 PM
  3. Ke70 Questions
    By Low Style in forum Technical - Questions
    Last Post: 12th June 2010, 06:32 PM
  4. Clutch Questions
    By MARKE70 in forum Technical - Questions
    Last Post: 3rd January 2008, 10:57 PM
  5. ke70 questions
    By slipps in forum Technical - Questions
    Last Post: 23rd August 2006, 05:48 PM
