Results 1 to 8 of 8
Thread: Advance timing
    Mar 2010
    Felix
    Philadelphia
    Philadelphia
    USA
    Howz it goin, I gotta 4age big port engine in my ae71 with a VL pump its running rich as and im looking at advancing the timing does anyone have any advice on how many degrees and the best way to go about it?
    gunbz-r
    20v u retard 4 degrees for 3kw atw lol dunno bout bigport tho, u doin it with out a dyno?
    hey i just had my bigport fixed, my one was running super rich, but timing wasnt the problem, it was a broken hose and somethin else disconnected, map sensor i think (try lookin round there?), then i had it advanced 20 deg
    -sorry for the shit info but im not a mechanic and i took it to an efi place and thats what he told me
    edit- my fuel pressure was too high aswell, check that
    Benn
    gold coast
    a big fuel pump will not make the car run rich, somthing else is wrong(map sensor, coolant temp sender, fuel pressure reg, leaky injectors).
    and timing won't fix it.
    I concur with Benno
    gunbz-r
    yeh sorry i read that rong lol check ur fuel pressure extra flow might of causedd an old shitty fuel reg to start to fail
    Mar 2010
    Felix
    Philadelphia
    Philadelphia
    USA
    cheers. Im gonna put a fuel reg on it and take it to get dyno'd and tuned c wat they think. Havnt found any leaks.. yet.
    <div class='quotetop'>QUOTE (4age '71 @ Nov 23 2007, 07:42 PM) </div>Well I had a problem with my 16v conversion running super rich. Considered all options, couldn't work it out, turned out the return line was blocked. Check to see if you can blow air back through your return.
    P.S. I'm using a VL pump too.
  1. 20 valve timing cover spacer (middle timing cover, alloy plate)
    By KE70Man in forum Cars or Parts Wanted
    Last Post: 26th August 2011, 06:30 PM
  2. Heads up: Cheap re001 at Advance Tyres Richmond
    By geoff in forum Melbourne & Vic Events and Discussion
    Last Post: 31st October 2010, 11:30 AM
  3. where is the vacuum advance on a Aisin carby?
    By stantheman in forum Technical - Questions
    Last Post: 13th May 2009, 10:38 PM
  4. timing??????
    By weeman in forum Technical - Questions
    Last Post: 14th October 2007, 08:33 PM
  5. Timing
    By Gilly in forum General Topics (No Technical Questions)
    Last Post: 11th May 2005, 10:00 PM
