Results 1 to 6 of 6
Thread: Front Strut top bolt
    Jase
    South Australia
    Glenelg
    it seriously WONT budge!?
    i need it off to replace my springs, but it just isnt happening. I even got a socket on a bar and wacked it with the rear of an axe a few times. wont budge?
    Has anybody else experienced this problem?
    oh and i have the strut out and its off the lca.
    And is there a certain way you are supposed to get the strut back onto the lca? it seems too far down and i cant lever the lca down far enough to get the strut back in?
    GAHHH help me!
    Btw this is all on ke70 struts
    Senior Member Lost Prophet's Avatar
    Canning Vale
    You might have to try and find a rachet gun to use. Otherwise the shock just keeps spinning (assuming i'm thinking of the right bolt)
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    OMG r u serious ur doin it all wrong man put it back in the strut tower on the lca then undo it a little bit then take it out and undo the rest of it
    i had the same problem as u when i put my king springs in lol
    u wont need an air tools to tke it off
    i also found a lazy way to do it bolt the control arm on and let it touch the ground so u can lever on the socket to remove the bolt
    hope this helps
    Site Supporter Javal's Avatar
    Josho
    Get an air tool on the top nut and some vicegrips on the shock (not so tight as to score the shock).
    Will come off eeeeeeeeeeeeeeeeaaaaaaaaaaaaasy.
    Jase
    South Australia
    Glenelg
    thanks for all your help.
    Cant exactly wait around till xmas for my air tools lol
    but ill try unbolt the lca so i can get the strut back onto it
    then start from scratch
    Benn
    gold coast
    rattle gun FTW
    also try using a spring compressor, it'll save on your dental bill and make it easier to line up the shock shaft cutouts with the strut top when you replace it.
    and i'd advise against use multigrips or vicegrips on the shock shaft, sure-fire way to ruin shocky seals.
  1. Gas strut between strut top and engine
    By hugh in forum Technical - Questions
    Last Post: 26th August 2009, 11:09 PM
  2. top strut bolt
    By scott_22 in forum Technical - Questions
    Last Post: 19th March 2009, 11:55 PM
  3. Strut top plates - Brisbane
    By donp in forum Cars or Parts Wanted
    Last Post: 30th August 2008, 09:00 PM
  4. What strut top and spring hat to use???
    By Ksevn-T in forum Technical - Questions
    Last Post: 30th August 2008, 05:16 AM
  5. Broken Strut bolt
    By patience in forum Technical - Questions
    Last Post: 27th April 2008, 10:07 PM
