Results 1 to 10 of 10
Thread: Toyota JDM 4AG waterpump
    ~will also fit 4ac
    ~$60 ono
    ~PM me
    ~location SA will post
    Senior Member Stain's Avatar
    Derek
    Far North
    This RWD? Has the thermostat in it?
    Apr 2006
    u have pm
    no thermostat as it isnt attached to the waterpump!!
    Ted
    Genuine waterpump is just under $100 for an Ae82 4AGE. The front housing is the same as the RWD - the actual PUMP part, spit the housing and put the RWD JDM housing on, that has the thermostat assembly in it, and it fits together.
    $60 for the front pump, JDM or not, new, is pritty good.
    Oldschool Member
    Jan 2007
    Can I see a photo of the pump that you are talking about please.
    Paul
    Senior Member riceburner's Avatar
    <div class='quotetop'>QUOTE (Teddy @ Nov 25 2007, 09:55 AM) </div>
    Wrong
    I have the 2 side by side and the rwd front is definately longer due to clutch fan, FWD are shorter so not to hit the chassis rails. Longer studs too.
    But if your using a thermo fan then fwd are the same bolt pattern and could be used. You would need the crank pulley for the fwd if a rwd water pulley cant be sourced.
    RWD only really needed if you need the fan. You would need the different offset rwd water pump pulley aswell.
    Dam no digi cam either, to explain.
    $60 is great price.
    Insert witty comment here....
    OK guys the pump i have for sale is a 4ag jdm pump which has a longer shaft than a fwd pump (reason because it has a egine fan and needs to be closer to the radiator) it is an identical pump otherwise. you can use this pump on a fwd or a rwd engine just need the coresponding waterpump pulley! or will fit a rwd 4ac!!
    someone must want a toyota pump at aftermarket price?
    Veteran driftism's Avatar
    Andrew
    Watsoia
    EDDIE.... WHAT HAVE YOU DONE FOR ME LATELY??
    pretty sure dad will want this, i'll sms you.
  1. Brand New Genuine Toyota 4A-GE 16v Smallport Waterpump
    By eS22 in forum Car Parts For Sale
    Last Post: 24th September 2012, 01:29 PM
  2. Engine Parts 4ag jdm
    By cando1 in forum Car Parts For Sale
    Last Post: 19th August 2009, 07:20 PM
  3. JDM Belhousing on 4ag Really Required
    By hatzo in forum Technical - Questions
    Last Post: 18th December 2007, 05:48 PM
  4. 4ac waterpump same as 4age rwd waterpump?
    By simonster in forum Technical - Questions
    Last Post: 25th October 2007, 10:11 PM
