Results 1 to 10 of 13
Thread: Longer wheel studs
    Scott
    Qld
    jeff
    hey guys,
    Before you start baggin the crap out of me for my 'newbiness' let it be known that several searches were conducted before starting this thread with no bingo!
    Anyway, I recently updated my front end on the 86 with ajps coilovers,jdm brakes and a set of ol'scool Performance Spectra (?) meshies that are 15*7 +10 offset. Unfortunately with the coilovers adjusted down to their lowest position (the only position!) the lower spring nut rubs against the tyres. Only just mind you but enough that I shit it everytime i head into a corner.
    So I bought some 6mm wheel spacers but unfortunately now I cant even get the wheel nuts to grab the stud. After speaking to an engineer at work it turns out I need an additional 12mm of thread over stock. Ive spoken to Dave from AJPS but the studs he can get his hands on are only 6mm longer than stock.Apparently later model landcruisers are a direct replacement and provide an additional 12mm of thread over stock sprinter bits.
    So, does anyone have any experience with this? Is the Landcruiser idea fact or fiction? If fact, exactly what model troopy should I get the studs from? Any part numbers I can use? Any other ideas or suggestions? Any suppliers in Adelaide? Apparently Nice products have them but I need a part number...
    Thanks in advance for any help you can give :2thumbs:
    Go to Sprint Auto/Repco get some "Nice" Wheel Studs NS3400 which are M12x1.5 about 25-30mm longer than std and about $5.50ea.
    Site Supporter Javal's Avatar
    Josho
    You can get ones from Hilux's, which are alot longer, ask Craig_AE86 about that one.
    Also i think Sigma studs are 15mm longer
    parrot
    From the "things from other cars thread"
    I've just done these. I think David Lawson may have posted this earlier in the thread. Interestingly I had two different size studs on my AE86. The sigma studs are either 8mm or 6mm longer in my experience depending on what you already have. I looked at a variety of mitsubishis and nearly all the 4 stud cars run the same wheel stud across a few generations.
    So probably too short for your needs.
    Elite rthy's Avatar
    Leo
    Tulla
    i got some long ones from autoone (in melb)
    $7 for like 12cm...
    Terry
    Ipswich
    stocked by
    Senior Member SLO-030's Avatar
    Ryan
    Southern 'burbs
    <div class='quotetop'>QUOTE (741 @ Nov 28 2007, 12:56 PM) </div>
    <div class='quotetop'>QUOTE (Javal @ Nov 28 2007, 01:01 PM) </div>
    They are the "NICE" product i used.
    bass_2000_au_au@hotmail.com says:
    they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
    Jonathan
    Most Toyota studs could be used, and I guess HiLux of HiAce ones would be good.
    You can use Lancruiser HZJ80 in theory, not sure of length. But you can't use late model Landcruiser JZJ105, HZJ105, HDJ100, UZJ100 etc, they use bigger studs and nuts. You use a 21mm socket on normal Toyota wheel nuts, newer Landcruisers use a 22mm socket.
    You can buy new HiLux/ old landcruiser wheel studs on e-bay. (Non-genuine, from China).
    Scott
    Qld
    jeff
    cheers everyone for the wikid response. :2thumbs:
    Ive ordered some Nice ns3400 following everyones advice and am going to have a shot at ramming them in this weekend
    Repco sure stood up to their name and charged a whopping $12 per stud and nut ($96.00 just to do the front)
    Elite rthy's Avatar
    Leo
    Tulla
    I am going to add this to the FAQ
  1. Longer studs
    By Low Style in forum Technical - Questions
    Last Post: 15th September 2010, 09:41 PM
  2. Longer wheel studs for AE86
    By wideslider in forum Cars or Parts Wanted
    Last Post: 2nd November 2009, 01:39 PM
  3. Longer wheel studs
    By dr1ft-pig in forum Technical - Questions
    Last Post: 22nd March 2009, 11:46 AM
  4. Longer Wheel Studs
    By sonsta in forum Technical - Questions
    Last Post: 12th March 2009, 06:55 PM
  5. WTB longer than std wheel studs
    By ae71 in forum Cars or Parts Wanted
    Last Post: 26th March 2008, 05:29 PM
