Results 1 to 10 of 10
Thread: headlight bulbs
    hey people,
    another question, just wondering what light bulbs u guys have, casue i bought some ages ago ,4500k ones, my old one screwed up so i used these and they're really crap (they have that blue tinge to them which i think effects them heaps). I was running phillips 50/100w i think and a less 'K' , so im just wondering which ones u guys use.
    Site Supporter Javal's Avatar
    Josho
    <div class='quotetop'>QUOTE (Johnny_08 @ Dec 3 2007, 12:57 AM) </div>The higher 'K' ones will give superior lighting in pitch black conditions, but they're crap in low light situations.
    get something closer to standard, or a HID kit methinks.
    Veteran Konakid's Avatar
    Henry
    Eastern
    the light actually gets less brighter (lumens) past about 6500K ive read.
    I had shitty hektic blue globes that were junk they came with the car. Bought some Phillips 50% brighter factory replacements and they were much better, awesome light.
    which ones were they and where did u get them kona, also what the standard?
    Benn
    gold coast
    K stands for kelvins and is a temp measurement, it refers to the burn temp of a HID bulb, if a standard incandesant globe says it's a "4500K" then it's a wank. they are just relating to the colour of the light output.
    with HID the higher the burn temp the lower the light output in lumens, 4500k-6000k is your white light output, anything after that the light changes through blue to purple and output(L) drops off steeply
    Josho
    <div class='quotetop'>QUOTE (Benno @ Dec 3 2007, 07:04 AM) </div>Not entirely correct.
    Their output doesn't drop off.
    It just moves out of our visual range...
    Benn
    gold coast
    that why i said "light output in lumens", because lumens is a measurement of visable light, thus Visable light output drops.
    but yes in the terms of broad spectrum light,you're right, the light moves out of visable range and into ultra-violet with higher burn temps.
    Josho
    <div class='quotetop'>QUOTE (Benno @ Dec 3 2007, 01:36 PM) </div>Aaaahh, gotcha. You learn something new every day.
    Senior Member Moebius's Avatar
    Christian
    I've used both phillips bluevision and visionplus and they're both good, bluevisions being slightly better. Also note that even though they are called bluevisions they are just bright white, not wanky blue.
    are there any types of phillips bluevision, like different K's alsohow many wtts do u guys reccomend
  1. light bulbs
    By stx-16 in forum Technical - Questions
    Last Post: 5th August 2010, 09:49 AM
  2. Cluster bulbs
    By haydenz in forum Technical - Questions
    Last Post: 7th October 2009, 02:46 PM
  3. parker bulbs
    By loc33e in forum Technical - Questions
    Last Post: 5th February 2008, 10:40 PM
  4. HID Replacement bulbs
    Last Post: 22nd May 2006, 01:55 PM
  5. Brighter Bulbs
    By SIC86 in forum Technical - Questions
    Last Post: 21st July 2005, 08:45 AM
