have you tried connecting the earth wire?
my parkers dont work.
i was looking in the woring diagrams and i cant see which wires are for the parkers.
when you take the black instrument cluster cover off, which wire on the plug for the headlight switch is for the parkers?
i noticed that the black one (which i am guessing is the earth) has been cut and not reconnected. everything else works fine with the lights (headlights, indicators, tails etc), its just the parkers that arent working
<div class='quotetop'>QUOTE (chapl @ Dec 7 2007, 10:44 AM) </div>of course i have. no effect
buy a multimetre and start searching!
i will as soon as i know which wire on the headlight switch plug is for the parkers
*edit*
i already have a multimeter
*edit 2*
thats for everyones help............
but the black wire ended up being the analogue switch for the brightness of the dash instruments. if its not connected theyre always on the brightest setting (the one i like) so i left it disconnected.
the wire i was after for the parkers is the green wire. same wire as so many other things on the loom. this wasnt the problem however. im a moron, i checked absolutely everything which took me hours and then i almost gave up and decided to see if the parkers would blink if i wired them up to the indicators. they didnt. i put the indicator bulbs in and they did..... so it was the bulbs all the time.... thats 4+ hours im never getting back.
note to self:- always check bulbs first
