Results 1 to 9 of 9
Thread: ke70 suspension
    upgrading springs in the ke been told that falcon springs fit, do i just get a pair of rear springs
    and chop them in half? so they can go on the front aswell. i did a search but wanna know if the springs
    fit in the front aswell
    Veteran Konakid's Avatar
    Henry
    Eastern
    No get fronts for the fronts, and rears for the rears, half will be too low, make them about 270mm free height all round and then cut more from there if need be
    So your saying that falcon front springs will fit onto the front only of a ke?
    I always thought that it was just the rears that could be used all round..?
    Jase
    South Australia
    Glenelg
    i used fronts in the front. Fit well.
    Senior Member superbmobile's Avatar
    Justin
    Happy Valley
    i once used vl rear springs in the front of my ae70. They seemed to fit pretty perfectly in the standard 70/71 strut. And seemed to be around a 4kg rate so they worked alright as a buget setup.
    Justin
    Happy Valley
    i once used vl rear springs in the front of my ae71. They seemed to fit pretty perfectly in the standard 70/71 strut. And seemed to be around a 4kg rate so they worked alright as a buget setup.
    Oldschool Member
    Aug 2007
    How about if you have a set of king or pedders from a falcon spare? what would the approx spring rate be if they were cut down a bit. The springs are Super Lows.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    cutting springs doesnt change the spring rate it only makes it have less travel
    FTP.
    Henry
    Eastern
    Actually it does increase the spring rate due to less coils having more resistance
    A cut falcon rear spring is about 4kg depending on height. Front would be about 5, also depending on height
  1. S13 suspension setup for ae86/ke70. Plus Other ke70 parts.
    By Da_Hachi in forum Car Parts For Sale
    Last Post: 28th January 2011, 10:04 AM
  2. Stock KE70 suspension and 2 KE70 front doors in GOOD CONDITION
    By Clinton in forum Cars or Parts Wanted
    Last Post: 13th December 2010, 04:53 PM
  3. KE70 Suspension help
    By vicko_bwood in forum Technical - Questions
    Last Post: 19th October 2007, 06:24 PM
  4. KE70 suspension?
    By flegburt in forum General Topics (No Technical Questions)
    Last Post: 15th October 2007, 01:59 PM
  5. ke70 suspension
    By kiwi in forum Technical - Questions
    Last Post: 14th March 2007, 01:01 PM
