Results 1 to 10 of 15
Thread: Speedo/Tacho and a T50
    riojin
    ive noticed a difference between my last two ae86's
    my last car with a standard ADM T50 would rev at about 2950rpm when going 100km/h in 5th gear
    my new car with a standard ADM T50 revs at 3100rpm when going 100km/h in 5th gear
    i opened up the guage cluster in my new ae86 to make the tacho work with the gze. i bumped the needles and tried to put them back in place to the best of my ability.
    so the question is, how much is your engine revving with your ADM T50 when going 100km/h in 5th gear?
    Mar 2006
    Same diff ratio's?
    Nov 2005
    just under 3000rpm with adm diff
    3100rpm with jdm diff
    did your two cars have different final gears?
    Ferny Grove
    maybe one has 3.7 or 3.9
    and the other
    4.1
    ** If both diffs are T series (S series is 3.9 as well)
    riojin
    im guessing they were both the 3.9 ratio s series diff. i may have a t series rear end but havent checked. i do know its drum however. is there an easier way to check the diff instead of getting under the car and measuring the housing?
    Ferny Grove
    count the nuts holding the diff centre in
    8 = s series
    10 = T series
    S will have 3.9
    T will have either 3.7, 3.9 or 4.1
    my guess is both cars have a different diff ratio/diff
    Site Supporter Javal's Avatar
    Josho
    <div class='quotetop'>QUOTE (Gilly @ Dec 20 2007, 11:08 PM) </div>4.3 for T series are also common, but not standard for TE72 / TE71 / AE86 (JDM)....
    ...you'll find them in automatic celicas.
    riojin
    s series, 8 nuts.
    so my guess is the needles that i bumped when opening up my cluster arent in the exact right spot. most likely the speedo. it doesnt look like its sitting as low as the tacho needle (meaning im speeding when i think im doing the speed limit). ill open her up when i can be bothered and fix it.
    Felix
    Gold Coast
    i sit at around 4000 revs at 100km
    think i have either a 4.1 or 4.3 in my t series
    Jonathan
    In 5th gear at 100km/h with 185/60R14 tyres, in theory means:
    3091 rpm with 3.909:1 final drive
    3242 rpm with 4.1:1 final drive
    3401 rpm with 4.3:1 final drive
    3717 rpm with 4.7:1 final drive
    In 5th gear at 100km/h with 195/60R14 tyres, in theory means:
    3029 rpm with 3.909:1 final drive
    3177 rpm with 4.1:1 final drive
    3332 rpm with 4.3:1 final drive
    3641 rpm with 4.7:1 final drive
  1. t50 speedo drive
    By Jacobxxx in forum Cars or Parts Wanted
    Last Post: 11th August 2011, 03:07 PM
  2. t50 speedo drive
    By timbo in forum Technical - Questions
    Last Post: 14th April 2010, 09:52 PM
  3. ae71 tacho dash and speedo cable
    By wide s13 in forum Car Parts For Sale
    Last Post: 22nd March 2009, 05:07 PM
  4. T50 speedo drive gear
    By GreyNomad in forum Cars or Parts Wanted
    Last Post: 18th August 2008, 08:13 PM
  5. tacho and speedo probs
    By driftke70 in forum Technical - Questions
    Last Post: 2nd November 2006, 11:59 PM
