hey guys,
ive got a 4agze turbo which is curretly being rebuilt, i fall under new P plate restrictions for VIC and i was originally planning to sell my car but i am now considering swapping my rebuilt GZE with all accessories (Turbo 3"inch Dump + full exhaust, ECU, FMIC, Piping) for a N/A 4age, modified or not with appropriate cash adjustment.
some specs:
· Series II 4AGZE (AFM + CAS) running factory GZE ECU
· KKK 26 350hp Turbo, I believe it is from an Alfa Romeo Alfetta 2.0 (ball bearing)
· 35mm External Wastegate (running on 6psi)
· Tuned Length Manifold (heat wrapped)
· 3" Mandrel Stainless Exhaust from turbo, Resonator and Cat (front 1/3 heat wrapped)
· Large FMIC 600mm x 400mm x 80mm
· VN Throttle Body 75mm (no Idle control valve or switch)
block was cleaned, and honed, new Bearings, and pistons rings installed. New water and oil pump Head was disassembled, shaved, cleaned and rebuilt.
this engine package could easily give around 140rw kw plus
I DO NOT YET HAVE THE ENGINE BACK
PM me if you're interested.
