Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 40 of 43
Thread: 4agze Turbo
  1. #31
    Stuart
    Nsw
    hey mate would you ship it it sydney.
  2. #32
    Vic
    SE Burbs
    has the engine been run at all? hub dyno? any kind of figures?
  3. #33
    i have a fresh rebilt 100kw small port only done not even 1000km since rebild
    i would be lookin at a strait swap if your keen?
  4. #34
    Bert
    <div class='quotetop'>QUOTE (todd @ Jan 11 2008, 12:56 PM) </div>nup, i didnt originally make up this engine, i bought it blown and rebuilt it.
  5. #35
    Bert
    <div class='quotetop'>QUOTE (toyota2cam @ Jan 11 2008, 06:02 PM) </div>
    may be close to, if you have some other goodies i can use then even higher chance, i have a nice offer from someone on here for a bigport with 7-rib, rebuilt a while back, welded diff with a bit of cash.
    hope that helps out with your question, PM me a price, or other things you have if you're still interested
  6. #36
    well it comes with loom allready hooked up in a rwd car has all the jdm rwd water pump gear alt as well cut and shut intake crome cam covers and a extreme clutch kit less that 1000kms old ive spend a heap on this motor so im just after a swap if your keen
  7. #37
    Vic
    SE Burbs
    <div class='quotetop'>QUOTE (choonga @ Jan 11 2008, 03:54 PM) </div>Yes? No? I'm very interested mate...
  8. #38
    Bert
    <div class='quotetop'>QUOTE (choonga @ Jan 12 2008, 04:04 AM) </div>Yes? No? I'm very interested mate...
    [/b][/quote]
    engine has not been run, will need to be broken in.
    engine was running before build, one piston was destroyed but it still ran.
    no power figures except what one can expect from a Ball Bearing Turbo'd GZE
  9. #39
    I can vouch for the quality of toyota2cam's rebuilt rwd smallport if you are considering it, certainly no corners cut. The cut/shut inlet manifold is also neat since he is a welder by trade, it has all the RWD gear from a genuine AE86 4age to! i think the clutch is brand new to and not cheap!
  10. #40
    Bert
    <div class='quotetop'>QUOTE (ae93_sx @ Jan 12 2008, 07:02 PM) </div>thanks man, i think possibly if i was to consider this swap i would keep my flywheel and clutch, as its a 3puck button which has done 300km, and you're friend would be able to keep his clutch and flywheel.
    i should be getting pics up and a list of exact details of whats been done in the build half way thru this coming week.
    cheers guys
  1. 4agze to turbo Q's
    By Wyma in forum Technical - Questions
    Last Post: 24th January 2011, 09:14 PM
  2. WTB microtec for 4AGZE turbo
    By wattsys86 in forum Cars or Parts Wanted
    Last Post: 21st June 2009, 05:39 PM
  3. 4agze 20valve turbo
    By DriftPlease in forum General Topics (No Technical Questions)
    Last Post: 15th January 2007, 08:23 AM
  4. 4agze turbo?
    By juguar_19 in forum Technical - Questions
    Last Post: 7th December 2006, 01:25 PM
