There is a type of sigma LCA which bolts straight in but you will need RA40 celica tie rod tubes and tie rod ends so that you have enough toe adjustment.
What are your reasons for not wanting to run wider and lower offset rims to increase track? This is the best way to gain extra track as it doesn't make the steering heavier due to keeping the scrub radius 'closer' to factory. The steering will feel much more accurate due to not having skinny wheels far apart, instead using rim width to gain the extra track outboard that you want (using a lower offset) and more inboard also due to wider rim.
