BAH
well we all like balls on our shafts
well i can tell you how to acchive this phenominal mod
get a golf ball (many colors to choose)
get a drill bit 10mm
bit if you have a 12mm use it
clamp golf ball in vice or simmilar or clamp if ur using a press
drill to ablot half the hight of ball then remove your old poo brown knob
then force down your golf ball onto shaft it will self tapp due to softer material
then when threads covered up all done
i use one in my car verry cool
[attachment=20279SCN1648.JPG]
JAPANESE DOMESTIC MARKET AS F*CK!!! hmmm, when you prenounce it properly, it sounds gayhow bout that.
better than stock
have to see pics otherwise it never happend.
haha this souinds great.
Make sure you dont use a golf ball with a liquid center then. Most range balls have a solid center
or those fake golf balls that explode into dust when you hit them?
pics up and yes use solid centres
cheaply available from your local driving range by fence for free
Did this like 2 minutes aftrer reading. Pretty cool. I found if you just use a 10mm and sort of test then round it out some more then re-test untill you get a good fit.
Only thing is there's now a gap between the ball and the boot.
Picture:
[attachment=20286hoto_0240.jpg]
nice looks the goods
as good as cusco and nice feeling in the hand whilist shifting
but dont worry bout gap
looks 110% better than anything at stuper cheap or ricobahn
Wish I had a fluro green or pink one now![]()
