Ok, im having a bit of trouble figuring out how to get a reliable spark on my Weber'd 4AGE. I can't use a standard 4AGE dizzy as it has no advance mechanism and i would have to buy a few different MSD products to create my own timing curve. I also do not want to run static timing even though i have read that it works ok. Another option is to get a 4K distributor and adapt it to fit, even though it's points, coil i think.
However i was thinking that maybe a 4AFC distributor might work, i know i may have to make an adaptor and change the gear. I presume that it has an advance mechanism and maybe vac. advance as it is a carby motor? or is this not the case?
Has anyone done any research on this or has got a Carby 4AGE and can help me out?
Thanks Daniel
