Results 1 to 7 of 7
Thread: hilux diff?
    Oldschool Member
    Oct 2007
    so whats with the hilux diff, i see people using them, are they trustworthy? wats the rough price of them? anything i should watch out for?
    cheers guys
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    <div class='quotetop'>QUOTE (that @ Jan 1 2008, 05:17 PM) </div>Hilux diff strongest diff arond for the ae/ke also the heaviest requires modification to shorten the diff and add spring seats as it uses leaf springs also need swaybar mounts welded on but u dont have to do this. they can use a lsd in them but they are expensive arond $300 mark plus the cost to get the work done. the one u want is a g series diff out of an rn41 hilux
    Edwin
    Colyton
    By using a g series diff, how bad does it affect the handling of the car?
    How hard is it to handle?
    For the people that has gone through the g series route, how much roughly did u guys spend?
    Aug 2006
    The diff is indeed out of a rn41 hi-lux an 1983 model actually, they are 1410mm in length, if you measure your sprinter diff it should be pretty close so all you will have to do is change stud pattern on your axles and transfer your suspension brackets from your s- series to the hi-lux diff. Nissan r-31 rear discs have same stud pattern as sprinter but you will have to machine 5mm off the flange of the hi-lux axles to fit the discs on. Craft differentials in Granville may still do caliper brackets for this conversion. I hope this helps.
    Cheers Mick.
    Oldschool Member
    Oct 2007
    thanks guys, uve been great help,
    my mate has a spare diff from his 94 hilux i think it was.
    would these still be suitable in a ae/ke setup?
    Elite rthy's Avatar
    Leo
    Tulla
    its suitable if ur putting 200rwkw from a 4kc
    Aug 2006
    A turbo helps,
  1. Replies: 0
    Last Post: 1st July 2012, 01:36 PM
  2. Hilux Diff
    By wideslider in forum Car Parts For Sale
    Last Post: 27th May 2010, 08:36 PM
  3. hilux diff
    By DRF17 in forum Car Parts For Sale
    Last Post: 13th June 2009, 10:22 PM
  4. Hilux diff
    By joshz18 in forum Car Parts For Sale
    Last Post: 8th June 2009, 10:38 PM
  5. hilux diff
    By Fozz in forum Technical - Questions
    Last Post: 4th June 2009, 10:08 PM
