just a quick question, does a rwd 4age clutch fit a 4agze.
thanks
(im not lazy,i did a search but couldnt find anything)
thanks
No a RWD 4age clutch is 200mm daimeter and gze if i am correct is 225mm
bass_2000_au_au@hotmail.com says:
they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
It depends on what you mean with the question.
The important thing about clutches is the disc diameter and the splines. The disc diameter must match the flywheel, the splines must match the gearbox input shaft.
Search around for 4AG flywheel info, there are 200, 212, 224 and 230mm variants. All have the same 8 bolt pattern to attach to the crank.
A RWD 4AGE clutch will most likely be 200mm, with splines to match a T50, this can be used on a 4AGZE with a T50 providing you have a 200mm flywheel.
thanks for the help boys
100% correct. i run a 200mm flywheel which was off an ae80 or so it said in white out(obviously from wreckers) with a clutch matched to 200mm flywheel
