Selling a whole bunch of gear that is surplus to my needs to raise money for some sweet wheels.
All is in brand new or very good condition.
Located on the Gold Coast, would far prefer pickup but will consider post on smaller items. I'll travel a bit to meet for pick up if that helps too.
Pm me or call on 0420318141
1. 13 x 6 Cheviot Jellybean mags with 114.3 x 4 pcd, unknown offset. All have some gutter rash but straight and in good nick otherwise.
Strong and light, only 6kg each . Have been used for racing previously. $120
[attachment=20667SCN0563.JPG]
2. Ke70 front brake upgrade complete setup. UNUSED since rebuild, straight bolt on. Perfect budget racing or drift upgrade for Ke70.
15mm larger discs, larger calipers and pads. Discs machined, new pads, all bearings new. Creates extra 3 degrees neg camber. $220
[attachment=20668SCN0570.JPG]
3. Perfect condition 5k/4k camshaft, FRESHLY REGROUND and UNUSED, by Watson Racing Cams.
Is longer duration or 'bigger' than the one in my setup (135hp 5k), suits more of a mid to top-end power band. In the right setup would make around
150hp. $100
[attachment=20669SCN0566.JPG][attachment=20670
SCN0567.JPG]
4. 5k water pump 77mm hub. BRAND NEW still in box, only been dummy-fitted. I think it will fit a 4k? Someone correct me if I'm wrong. These are import stock at all parts shops $135 new. $80 from me!
[attachment=20671SCN0569.JPG]
I think all the prices are pretty fair and reflect the condition of the items, therefore, don't lowball me!
But if you are seriously interested then I'm willing to talk.
Cheers!
