Results 1 to 10 of 12
Thread: Stock 4age's and boost
    Jarryd
    Sunshine Coast
    What sort of boost can stock 16V 4age's handle reliably? What power atw are we talking with a T25 sized turbo?
    Is it possible to purchace decompression head gaskets for running more boost?
    Senior Member gg004's Avatar
    Glenn
    Queensland
    Gold Coast
    depends how its tuned. hich compression and turbos can go together only if they are properly tuned to run that way. if you just slap on a turbo and pump big boost in, it wont last long as the detanation will melt nice holes in your pistons
    2013 Toyota 86 GTS 4U-GSE
    1983 Toyota Sprinter AE86 4AGTE
    1967 Toyota Corona 1600S Coupe RT51 4R
    riojin
    just do it to a gze. its cheaper and easier than forged internals for a 16V.
    unless you are planning on using stock internals.... if youre going to use stock 16V internals i give you a week max before she blows
    Rob
    Moorabbin
    turb up a 3 rib
    pretty common half the garage dori dudes run 15psi on stock 3 ribs
    if you want 150+ gze other wise upto 150 is sweet
    Ok
    Seamus
    Milton
    I was going to say, about 120-150rwkw will be fine. At that power level, gearbox diff and engine are all getting near their limit (thrashing them, that is). So kinda a good level to stick at
    ^ Clicky clicky!
    andrew
    yeh try break everything all at once
    old mate used to put the gze stuff on a ge and had no probs with 12psi he was belting that for a while.
    Adan
    Oxley Park
    ive been driving mine daily for about 4 months.
    the owner before me had it for just under a year.
    and the owner before that put it all together...
    I have a stock smallport with turbo and complete gze eletrics (comp, CAS, wiring, everything)
    I run about 4psi normally.
    Ive always wondered how much i can safely run without too much worry..
    *wait, it has gze cam covers, maybe that stops it from blowing up
    Jarryd
    Sunshine Coast
    Thanks for reply's..
    I would be happy with around 130-140rwkw
    *Just to clarify stock driveline should hold up ok at this power level if I don't intend on drifting?
    Senior Member mr2drift's Avatar
    130-150 rwkw will be fine if you take it easy..... my one of those ran for 2 years and then, only the head gasket went no damage to internals
    stefan
    vic
    eastern suburbs
    <div class='quotetop'>QUOTE (mr2drift @ Jan 10 2008, 08:36 PM) </div>i run a big port 16v and have the turbo manifold to suit. im running a greddy emanage on a jdm ecu. is it true that all i need to do now is get a 4efte map sensor to read the positive boost and im sweet?
    also how much would i be looking at for purchasing the necessary flexi pipe shit that toyota uses on supras etc? more or less than getting some staino piping made to suit?
  1. WTB: (SA) 4age stock exhaust secondaries and stock air box
    By Beige_Hornet in forum Cars or Parts Wanted
    Last Post: 22nd July 2011, 12:53 AM
  2. 4AGE RWD INTAKE, APEXi Boost Gauge, T18 Tail lights - MELB -
    By hitoriko in forum Car Parts For Sale
    Last Post: 5th January 2011, 03:25 AM
  3. Fs: (syd) boost gauge, rwd 4age bits...
    By sanitora in forum Car Parts For Sale
    Last Post: 15th April 2010, 10:25 PM
  4. T3 camwheels, T3 nrca's,boost gauge
    By GZE KE70 in forum Car Parts For Sale
    Last Post: 20th April 2007, 07:55 PM
  5. Dorio's stock sprinter
    By Dorio86 in forum AE86 Owners Forums
    Last Post: 21st December 2005, 03:41 PM
