Not sure whether it would help but before modify the stock ones try the ones out of the ke70/ae71 both manual and auto models
just wondering if anyone knows if there is another accel pedal that bolts into a sprinter to move it closer to the brake pedal. i know the jdm one does, anything else fit?
i will prob end up just modifying the stock one but i thought id ask first.
Rust is a way of life
Put it in the vice, use a ring spanner and bend it.
SamQ covered this, do a search ffs. KE70 i beleive is a direct bolt in upgrade
I did thanks medwin, the ae71 model and presumably the KE70 have a peddle that is about 10mm closer to the brake, worked wonders for me. I cant speak for the auto versions I havent checked
30kw club
just got jdm
they look sick too
just don't let the popo see it as they are apparently illegal, even if your car gets complied with one.
bit late but i thought id mention that i tried an AE71 accel pedal out of an auto and its the same as an ae86, same part number and all. only tried it cause a wreck came into work on its way to scrap so i pulled it out along with the lights and tacho dash![]()
I think they have the little counterweight thinie at the top like a ADM car which the JDM ones don't have.
It's interesting re the metal pedal and whether it is legal or not, as I think quite a few modern cars now come standard with a steel accel pedal.
