Wheres the ex mani from?
looks like one of your vacuum lines on the 3way block is kinked. Nice work otherwise, gotta love cable ties
Here's mine as it sits now, still minus a dump pipe and I'm redoing the oil drain.
and here's my oil drain, the hose is kinked a little bit but it still seems to flow quite well. I'm going to make it come straight downd from the turbo in front of the engine mount to the sump rather than around the back.
I ended up getting all braided lines for my turbo oil feed cost me $130 also picked up a 180sx custom dump pipe 3" which fits perfectly for my high mount setup
Cuzzo thats an ajps kelway manifold
What did you do for the water in/out on the turbo ? noob question but which one are the heater lines i needa tap into and what size tee do i needa use, have you got a pic of your water supply setup
mine came with the braided water lines. The heater lines on mine were the ones that go through the firewall to the heater, I just T-d into each of them.
ok where did ya get the t from enzed ?
Would it be possible to just run one hose in a Series threw the in / out of the turbo for water then back into firewall were the water goes ???
That way instead of using t's i need use reducers for the hose and also in winter i can use the turbo's heat to make my heater warmer
<div class='quotetop'>QUOTE (reecegze @ Jan 30 2008, 07:07 PM) </div>Yeh I think you should be able to, the water will still run through the pipes though and you'll get lots of radiant heat next to your feet. (if thats where the hoses are in a ae86, they are in a 120y). I had one chinese T with my setup and had to pay $50 for the second one, made out of 4 different brass bits as then chinese braided fittings were a gay thread. If your lines are from enzed (enzed use speedflow I think) then they will have a T to fit.
ok i don't really want to use braided hose for the water supply .. i might goto a plumbing supplier see what i can sort out. I really wanna do it via one hose to get that heat from the turbo to the heater in winter lol
