Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Brake Lights Flash On Bumps
    Senior Member HYPNTK's Avatar
    Nas
    Manningham
    how about checking the level of brake fluid too while you're at it...its too simple i know, but you never know...
    Benn
    gold coast
    brake fluid won't put you brake lights on!
    need a little more info, so tail lights on and when you hit a bump your brake lights illuminate too? foot on brake and hit bump then brake light drop out?
    electrical problems are usually quite logical to figure out if you can identify what is actually happening.
    if you start from scratch then the adjustment of the brake light switch is the first thing I'd check(top of the brake pedal... it is adjustable!)
    Mike
    Id check the switch at your pedals
    Nas
    Manningham
    nah i suggested the fluid coz in one of my cars if the fluid is even just a tad under the line then the "!" light comes on under hard braking or speed humps.
    doesn't hurt to check but its probably not it
    Benn
    gold coast
    cars with a fluid level monitor/switch will put the handbrake light on when low (!)
    Oldschool Member
    Jan 2008
    ive noticed that the break lights are on when i get out of bed sometimes lol so where abouts is this adjustment for the pedal exactly? cheers guys
    Benn
    gold coast
    start at you brake pedal and look up under the dash, you should be able to suss it out
    yeh in my old ke30 the brake lights used to stay on, ther is a little switch above the pedal that when pushed it triggers the brake lights, ther should be 2 bolts for adjustement, put the switch a little further away so that u have to put the brake pedal in a lil more bfor the lights come on
    Oldschool Member
    Jan 2008
    after all this is was the stupid rubber grommet which acts like a bump stomp...has a indent that the switch ended up sittin in so the lights came on lol thanks anyway guys!
    Cheers Will
  1. Brake lights and reverse lights not working
    By Jacobxxx in forum Technical - Questions
    Last Post: 27th January 2015, 01:02 PM
  2. motor dieing on bumps
    By s13 james in forum Technical - Questions
    Last Post: 20th August 2012, 07:32 PM
  3. welders flash
    Last Post: 10th August 2007, 12:41 AM
  4. Clear Rear indicators Levin Brake Lights
    By kravit in forum General Topics (No Technical Questions)
    Last Post: 2nd November 2006, 10:58 AM
