if u were in melb that engine would be gone b4 u can say "spoontang" . is that a RWD alternator setup?
1. bigport 4AGE now comes with custom rwd extractors!!! will seperate for $200
-good compression
-i will supply alternator
-i will supply starter motor
-spigot bearing installed
-no clutch
$500
3.Xtreme Flywheel and Clutch **NEW**
-light weight flywheel
-1200kg pressure plate
-5 puck clutch plate
$1100
6.Brake Upgrade **ALL NEW**
- Hoppers Stoppers AE86 Brake Kit
- 290mm Slotted AU Falcon Rotors
- PRB Twin Piston Calipers (Black)
- New AE86 Hubs and bearings
- New Pads
- New brake Lines
- All mounting brackets and plates
- Bolt up kit to AE86 Struts
$1200
8. WADE Cams 280* **NEW**
-280* advertised duration
$500
**Suspension**
* AJPS Rear Springs 6kg - $150 *NEW*
* SuperPro Bushes Lower Trailing Arms - $80 *NEW*
* T3 35mm RCA's - $100 pr
MORE TO COME
Contact: James 0422259031
<div class='quotetop'>QUOTE (JDM-086 @ Jan 16 2008, 11:02 AM) </div>Im not 100% on the defintion of what is RWD alternator setup,
but it mounts on the inlet side..
thanks
dude im keen for the caster rods and the panhard rod how much post to brisbane 4301
if its a 4age alternator and mounts driver side with a bracket that bolts onto the block its a RWD setup, the FWD setup bolts onto the water outlet.... im pretty sure thats right.... if its a jap spec 4age its the RWD setup fo sho
<div class='quotetop'>QUOTE (KE70briskev @ Jan 16 2008, 12:12 PM) </div>pm sent
<div class='quotetop'>QUOTE (JDM-086 @ Jan 16 2008, 12:19 PM) </div>yeah def FWD setup...dam
<div class='quotetop'>QUOTE (HiLtOn @ Jan 16 2008, 12:33 PM) </div>thanks for that il send him a pm.![]()
good morning...bumP
if adjustable caster rods dont sell pm me
also wanna seperate ur camber tops if so ill buy
<div class='quotetop'>QUOTE (fat exa @ Jan 17 2008, 12:35 PM) </div>il let you know
