Hi all,
Have some parts from a project thats fallen thru.
First up, 3 Ribbed 4AG block. Block has been acid dipped, honed (1 thou I think) and decked (1 mm). Welsh plugs removed and painted Hi temp Silver. Has been unused and has sat under plastic cover for months. Over $200 worth of work done. Price: $150 ONO with engine stand (T type from Supercheap).
4AG Crankshaft. Smaller 40mm type from earlier 4AGs. Was chemically treated and measured, and found to be within normal factory sized diameters (Don't need O/S bearings etc.) Has seen better days and is need of a clean. Been sitting on shelf for months. $30 ONO.
Matching pair of Solex PHH40 Carbs. 40mm throttle body. I have never personally used them. In good condition, suited for rebuild or reconditioning. Comes with linkages and has no shaft play. $220 ONO.
Last up, 4AG Oil Pump. Reco'd with new gears. Has jelly applied inside for proper sealing first time. Comes with Toyota Genuine Seal. $40 ONO.
Parts are in Victoria, at Endeavour Hills, South East of the state. Will ship smaller items (eg. Pump and Carbs) but preference to local buyers. Contact me on 0402696373 as my computer is acting up.
Cheers,
Mark
oil pump is mine
30kw club
