Results 1 to 3 of 3
Thread: 20v ecus
    stock ecus any diff between black top and silver top and would a silver top be able to work off a blk top ecu??? cheers
    I have heard the black top ECU can run silvertop. You need to fit a MAP sensor and piss off the AFM, plus slightly change the COR wiring (because of MAP replacing AFM). Matt, of Toyospares fame, claimed that this combo ran better than stock silvertop management.
    Elite rthy's Avatar
    Leo
    Tulla
    the ecus are different, there manual to auto silvertop ecus are even different. Either one can be run on either engine if you use the loom for the ecu and also you have to do some mods to the intake if your going to run the blacktop ecu with the silvertop throttles
  1. 20v bt aftermarket ecus
    By dehney in forum Technical - Questions
    Last Post: 6th December 2012, 12:52 PM
  2. 4age Loom and ECUs
    By Nikkojoe in forum Car Parts For Sale
    Last Post: 14th July 2009, 08:19 PM
  3. Retuning stock ecus
    Last Post: 11th January 2009, 09:19 PM
  4. ECUs and Looms
    By foxtail in forum Car Parts For Sale
    Last Post: 10th July 2008, 10:43 PM
  5. Aftermarket ECUs ?
    By Jonny Rochester in forum Technical - Questions
    Last Post: 29th December 2007, 06:39 PM
