Page 6 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 51 to 60 of 72
Thread: How to: Guard flaring
  1. #51
    Joel
    Blackwood
    I did mine on my hachi entirely different.
    1. I pulled the lip out from underneath.
    2. Drilled out the spot welds.
    3. Seperated the inner from the outer guard.
    4. Cut away a portion of the inner guard.
    5. Flared the outer guard.
    6. Welded the inner back to the outer.
    7. Added some extra metal and fiberglass for added rigidity.
    8. Fiberglassed and bogged till the cows came home and shit was smooth
    9. Painted
    10. Enjoyed
    They turned out good.
    I like your idea though, but would want to weld back the cuts once flared.
    AE86 4AGE "Slowly but surely"
  2. #52
    E-Famous (Remeber your roots)
    Any more pictures of other methods?
  3. #53
    Andrew
    Here is my preoject. I actually started these arches before I found this thread. I have used a hammer/dolly, no cuts, no drilling the welds. I cleaned the inside of the lip before I started and it will be seam sealed before the stone guard goes on.
    1. Folded up the lip to the inner guard
    2. Begin flaring the guard by gently heating(with gas) the inner guard and beating it out with the hammer/dolly. This gives much more tyre clearance.
    3. Gently flare the outer guard using hammer/dolly and gas. Most important is to get the edge radius correct without any dings or undulations.
    4. Skim of bog and 2k primer.
  4. #54
    Veteran Todd's Avatar
    Feb 2010
    Todd
    SOR Perth
    mintah!
    what 'gas' did u use?
    I'm guessing u would be reffering to some type of gas powered heatgun but I'm not too sure what u mean.
  5. #55
    Andrew
    Yeah, just a mapp gas torch. Not oxy or anything that heavy. It only needs a light heat. Moreso for the inner guard than the outer.
  6. #56
    Senior Member blacktopspirit's Avatar
    Brendan
    Eastern
    I used a Gaurd Roller on mine, works out pretty cheap if you buy a gaurd roller then sell or rent it out when you have finished.
    Front right Standard
    Front right rolled without inner lip
    Front left rolled with inner lip
  7. #57
    Veteran Konakid's Avatar
    Henry
    Eastern
    ^^Take the centre caps off the superlights, look waaaayyyy better.
  8. #58
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Fucking noob question I know. But when doing front guards you actually pull the whole thing out and cut/trim off the plastic liner mounts to achieve your outside edge? I started doing one of mine dodgily by just pressing the inner lip to the main flare and hitting it all outwards.
    Is the pulling out and cutting/trimming way the preffered for max clearance? Or is it how it's always done.
  9. #59
    Brad
    Central coast
    <div class='quotetop'>QUOTE (Dish @ Mar 22 2008, 06:16 PM) </div>
    i did not pull and cut. would be to hard the get the edge looking nice. plus less reinforcement.
    i folded that lip under then hammer and dollied that crease flat.
  10. #60
    Nov 2006
    <div class='quotetop'>QUOTE (Dish @ Mar 22 2008, 06:16 PM) </div>just rack off the plastic liner! bend out the inner section with your shifter and do the rest as steroidchicken said, folding the lip gives extra strength and gets rid of the sharp edge! hammer n dolly is the way a a light skim of bog to make her perfect! more that 1 - 2mm is 2 much! spend time with the hammer n dolly and make it as perfect as u can
  1. guard flaring
    By pet0r in forum Brisbane & QLD Events and Discussion
    Last Post: 27th December 2010, 12:02 PM
  2. guard flaring
    By Brenton 86 in forum Brisbane & QLD Events and Discussion
    Last Post: 16th April 2009, 11:25 PM
  3. guard flaring
    By ke_70 in forum Adelaide & SA Events and Discussion
    Last Post: 24th March 2009, 08:44 AM
  4. flaring guard help
    By grassworkzgarage in forum Technical - Questions
    Last Post: 4th July 2006, 03:47 AM
