Results 1 to 10 of 14
Thread: Pics of ITBS w/ Trumpets
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    does any have any pics of an ADM 86, with a 16v, T3 itb adaptor and T3 TRUMPETS, just wanna see if it clears the brake master cylinder as these are 75mm
    Cheers, Rich
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Veteran DRFTPG's Avatar
    ADAM
    <div class='quotetop'>QUOTE (drftr86 @ Jan 21 2008, 12:38 PM) </div> if you keep an eye on ae86hachiroku's build thread he is soon to put a setup like that in his car, dont know if its adm or not though
    Richard
    South Oakleigh
    cheers for the heads up, any one else got pics of that set up in a car, i know mattysshop uses a t3 adaptor but unsure of the size trumpets
    SQ ENGINEERING
    NCCE
    its an adm with trueno front but chassis is adm none the less
    zilla
    nsw
    central coast
    <div class='quotetop'>QUOTE (drftr86 @ Jan 21 2008, 12:38 PM) </div>Here's some pics of mine with home made ram tubes. They are 65mm long. 75mm should just clear your brake booster, depending on how flared the edge of the trumpet is. However, it will make it harder to squeeze an air filter sock around it, because of the spring in the sock. Mine seems to fit ok, but the #4 filter is squashed forward against #3.
    Firstly, just the 20v throttles with the T3 manifold. It was pretty messy with all the fuel rail and harness crammed up above it. I have since ditched that harness so it will be much neater soon.
    [attachment=21305:a.JPG]
    Now, the trumpets.
    [attachment=21306:b.JPG]
    Trumpets bolted on (sorry don't have pic from above angle to show clearance at the moment).
    [attachment=21307:c.JPG]
    Arrangement with "long" unifilter socks. Sorry bad angle again to show how the #4 filter is pushed forward.
    [attachment=21309:d.JPG]
    Richard
    South Oakleigh
    thanks skit, that would do me, yeah so probably gonna have to cut down the filters to make them same size as no.4 yeah
    cheers again
    SQ ENGINEERING
    NCCE
    Veteran driftism's Avatar
    Andrew
    Watsoia
    using a ke70 brake booster can be useful as they are smaller and will to the job almost as well
    Jul 2009
    Kane
    Coburg
    also a celica one too
    Andrew
    Watsoia
    what model celica?
    robert nguyen
    hey skit where did u get those trumpets from or were they cumstom for u? they look very good.. i hate those shiny chrome ones
  1. Replies: 16
    Last Post: 11th April 2010, 04:01 PM
  2. Replies: 11
    Last Post: 15th January 2010, 02:58 PM
  3. Blacktop ITBs Stacks/Trumpets
    By Eircamae86 in forum Cars or Parts Wanted
    Last Post: 26th March 2009, 04:38 PM
  4. Filter Socks for trumpets/itbs/side draughts etc.
    By Mr Fujiwara in forum Cars or Parts Wanted
    Last Post: 15th June 2008, 10:55 PM
  5. Blacktop Itbs
    By damo46 in forum Technical - Questions
    Last Post: 16th May 2008, 04:01 PM
