Replace the fuse.
The clock will work again.
The fuse will blow again and the clock will stop working again.
Because there is something dodgy with the CD player. Probably a loose wire.
hey, i kind of have a problem on my hand at the moment, yesterday i was trying to fix my cd player, putting some new speakers and what not, and it all works normally. then i put all the cd player back, it didnt work, the led for the cd player when u take out the face flashes but it doesnt load. after awhile i realise that my clocked doesnt work either... i check the fuses and found that there was no fuse for the radio.
can anyone help me, could the missing fuse screwed it up?
Replace the fuse.
check the grounding on the deck is god.. run your own one to make sure, as the stock wire that i had was DODGY.. kept doing exactly what u are describing, running my own wire fixed everything!
Insert witty comment here....
all fixed thanks guys
