Results 1 to 6 of 6
Thread: MA61 LSD
    Andrew
    Hi there. I need a MA61 (or similar F series) LSD centre only. Stock or aftermarket is fine.
    I am located in Melbourne but am happy to pay reasonable postage.
    Andrew
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    Might pay to do a bit of research on toymods, maybe a mx83 diff would be a close to bolt in job?
    Would be easy to get a grande diff/centre, which is LSD equipped.
    Rob
    Moorabbin
    Hi mate, i can get a cusco type or a true trac
    both are mechanical
    let me know
    cusco around $1250
    true trac $1000
    Senior Member xsoarerx's Avatar
    Logan City
    but rember true trac is torsen type... not good for drifting - its ment for traction, they use it in the front end of hilux 4x4's
    cusco is a clutch plate type - good for drift and loosing traction. 1.5 way and 2 way.
    mx83 and is G serise diff, you can't use it.
    SXE10/GXE10 ALTEZZA/IS200 is F serise but you need to change the carrier bearings over for the correct diff.
    is $1250 a delivered price?
    Rob
    Moorabbin
    yes
    Andrew
    I'm not really interested in going around a corner the slow way ie. drif7en, sik bro.
    Does this mean that a torsen type will suit me better? Or a clutch type 1.5 way?
    Thanks
    Andrew
  1. MA61 LSD Centre - Brisbane
    By LittleRedSpirit in forum Cars or Parts Wanted
    Last Post: 1st December 2011, 02:54 PM
  2. WTD: YR22 F series, Nardi Horn B, MA61 LSD + gears
    By Konakid in forum Cars or Parts Wanted
    Last Post: 15th October 2009, 06:12 PM
  3. 2way oem lsd, 1.5way cusco lsd + 4.3 crown wheel
    By .ady in forum Car Parts For Sale
    Last Post: 25th September 2009, 01:38 AM
  4. Replies: 2
    Last Post: 3rd September 2009, 09:04 AM
  5. MX13 F Series 1410mm Diff with MA61 LSD and ST141 Disc Brakes
    By twentyEight in forum Car Parts For Sale
    Last Post: 14th July 2009, 07:37 AM
