1 small port block no head, has crank and pistons.
also another small port but has no crank and pistons but has the head which was not long serviced before being pulled apart. no ancillaries on either, condition cant be garunteed. case of beer (decent beer) gets both blocks.
1 bigport head complete, condition unknown. offers.
2 bigport FWD inlet manifolds, no throttle bodies. $20 each
2 4age altenators. one has no regulator. $20 and $10 for the one with no reg.
1 4age power steering pump and bracket. $20
1 stock ke slant front grill. condition ok. $10
1 AE71 tacho dash. plastic cover broken but you could swap yours over. $60.
1 4agze intercooler. comes with different alloy pipes which relocated the IC above the exhaust. what good this does i dont know. condition good. $40.
1 pair of KE70 tail light covers. just the lenses, no lights. good condition. $40
1 stock 4agze crank pulley. $40.
1 big port head reconditioned. spent a few hundred getting this head recondtioned by duncan foster only to let it sit on the bench the last 2 years. its dissasembled but has all the parts needed. never fitted. $200
1 ca18det air con compressor $20
1 pair of S14 4 piston calipers. painted red. has all the clips and shims but no pads. also the discs which are redrilled to 4 stud. paid $350 for these about 5 years ago when they were worth more, asking $250
all parts are located in Ingleburn, SW Sydney. they are at my workshop, but can be brought home to Camden for after hours pick up. prices somewhat negotiable.
