Results 1 to 10 of 10
Thread: Struts
    I might sound like an idiot here, but i need to know the length and thickness of an adm strut. And also are the struts the same as any other corolla?
    cheers.
    Veteran DRFTPG's Avatar
    ADAM
    t18 and ae86 struts are the same
    Jase
    South Australia
    Glenelg
    ae86 have slightly bigger brakes, only by a few mm.
    ADAM
    2-3mm if I'm not mistaken?
    Veteran johl's Avatar
    Johl
    main difference in struts is the width of the shock tube. as i recently found out u can put after market 86 shox into ke70 struts as the shock can't fit inside. they both look the same from the outside but yeh they are quite different
    sorry guys but i need to know the exact length in Millimeters of the bare strut on a ae86. not including the calipers ect etc. Measurement from the end where the two bolts go. Up to the bottom of the spring hat. Or if anyone knows someone i can call to get a exact measurement
    Cheers.
    Jay
    the strut body length is 380mm , I just measured mine up now, depending on what shocks you have the total length can go up to 600mm which will be the end of the shock shaft
    Rust is a way of life
    Andrew
    The external diameter is 50.8mm, close enough to 51mm
    Thanks for the help guys...
    Apr 2010
    <div class='quotetop'>QUOTE (SON57A @ Feb 3 2008, 12:04 PM) </div>Is this true?
    Someone told me that T18s have a different 4-bolt pattern where the caliper mount is?
    Is anyone able to tell the exact differences between T18 and AE86?
    The epc part numbers are different for the strut legs.
  1. Replies: 7
    Last Post: 2nd September 2010, 05:46 PM
  2. ra60 struts/ 86 strut inserts / t18 struts / steering knuckles
    By driftke70 in forum Car Parts For Sale
    Last Post: 19th August 2009, 06:44 PM
  3. ae71 struts vs t18 struts
    By TOY3TG in forum Technical - Questions
    Last Post: 6th March 2009, 12:07 AM
  4. Replies: 2
    Last Post: 27th December 2008, 07:00 PM
  5. FS: T18 struts, Locked borgy, RA65 struts, taco dash
    By Hokey in forum Car Parts For Sale
    Last Post: 18th April 2008, 03:12 AM
