Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: welding chassis advice
    john
    nsw
    liverpool
    hi guys.
    for the feb. month i going to re-weld the chasis to refreshen the body and stiffen things up .
    does anybody have any advice for me . like what to do and what not to do.
    um any links or even if you have a write up . i want to read it. LOL.
    any thing to do with welding your chasis, can you please post it here.
    welding speed. wire thickness. body pep. whatever it may be. not enough soild info on google. and on the forums alot of people saying they have done it on there cars, but don't really go into depth about it .
    thanks in advance.
    ps. once i get the info i want ill be doing a write up of the process from start to finish to help others out.
    Jonathan
    Well for welding, generaly you want a MIG welder of some sort. Use thin wire, about 0.6mm. Use gas of course. There will be a amp or volt selector switch. Put it on about 3 to start with. Have wire speed at about 3 also.
    You will blow a hole...
    To fill up a hole, reduce than amps, and increase the wire speed.
    Veteran DRFTPG's Avatar
    ADAM
    also don't just weld from front to back, you will need to do the opposite ends of the car at a time i think, this way it wont twist the chassie, oh and also this is a longgg slow process so take your time, not the kind of thing you want to rush because if you do you could fuck your chassie
    Elite rthy's Avatar
    Leo
    Tulla
    don't you mean 0.7mm wire?
    john
    nsw
    liverpool
    will gas less have the same welding strength as gas ?
    Elite rthy's Avatar
    Leo
    Tulla
    0.7mm with gas, thats what I use and I can butt weld two 0.7mm thick peices of sheet together (admitedly looking a bit shitty though). That size is particully well suited to pannel work and is the only size we use here at my work making trucks.
    Another issue I've heard of from Jez is that the weld tends to pool on the side of the join to which you have connected the earth strap. So consider making up a secondary earth strap to make a very good electrical connection between both sides of the join.
    Mar 2007
    good thread, i will be doing this soon so again as much info as possible will be greatly apreciated
    Ken
    Spearwood
    Make sure your chassis is completely clean, like inside the joints and such. When you try and weld on shit like glue, and whatever little things like sound deadening residue and seam filler, it starts to splatter and make welding hard and disgusting.
    So have a hook to pick it out, and a wire wheel at hand to clean it.
    Senior Member Patric's Avatar
    Patric
    Enfield
    Stich weld, not seam weld.
    There is nothing like spending ages removing bent panels from a fully seam welded car.
    where as with a stich weld, its alot easier to grind off, remove panel.
    Silver 86 Trueno Hatch.
    AE86 4age gear for sale - http://www.ae86drivingclub.com.au/fo...eats-Ae86-gear
    Side intrusion bars for your import - http://www.ae86drivingclub.com.au/fo...our-JDM-import
  1. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
