Results 1 to 8 of 8
Thread: 4age Alternator KE70
    Jase
    South Australia
    Glenelg
    Hey all i need some advice. Tried using search but no success.
    I'm wondering what people have done when putting 4ages in ke70s, and what they do about the alternator.
    considering sprinters and ae71's have external reg's, this is never really brought up on here.
    I'm not sure what can be done with the 4age.. if i run a 4ag carbs could i use the standard 4k alternator and just extend the wires to the clip? (seeing as its on other side of block)
    If i run EFI what are the best options? I'm not to keen on getting a auto elec involved as i don't have cash to blow. I want something that will have internal reg and can just wire up to the ke70 alternator loom clip.
    sorry if ive asked too many questions at once, and probably not making much sense.. but any help will be appreciated! especially from those who have done this conversion
    jase
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    no ke70 alternator wount have enough power to run although u can use an st185 altenator which has more power than the 4age one
    Sep 2009
    I grabbed a reconed 95 camery alternator. External fan, internal regulator. So just hooks right into battery. Just get creative with the mounting brackets.
    Jase
    South Australia
    Glenelg
    getting creative with mounts is no probs
    I'm liking the use of the celica and camry ones
    any others?
    4k alternator will most likely die on a 4age, Pulling to many amps and it wont like 7750rpm very often.
    Ferny Grove
    use the 4AGE one, i wrote a "how to wire" guid specific for a KE70 in the tech articles section, its actually quite simple
    Jase
    South Australia
    Glenelg
    ah sweet shal check that out. cheers gilly
    Oldschool Member
    Jun 2006
    I'll be using a Bosch 70 amp one from a late model falcon, mounts were the same and the one I have has an internal regulator. All I had to do was swap the pulley for a rib belt style pulley (spacing worked out fine).
  1. Wiring an alternator on a KE70 to 4age conversion.
    By tetsujin in forum Technical - Questions
    Last Post: 29th August 2008, 01:03 PM
  2. 4AGE alternator wiring in a KE70
    By Gilly in forum Technical - Articles
    Last Post: 27th March 2007, 09:49 AM
  3. KE70 + 4AGE + alternator wiring
    By dr1ft-pig in forum Technical - Questions
    Last Post: 26th March 2007, 04:08 PM
