Results 1 to 8 of 8
Thread: Reverse light
    okay. I'm pretty much stumped now. um i dl'ed the manual n everything ive gotten no luck.
    my reverse light doesnt work. we checked the bulbs theyre fine, and then we checked the lines they were shonky as.
    so we decided to check up froint. but only to realise... we had no idea where the lines lead to hahahahhaha so wheres it go?
    Phirom
    <div class='quotetop'>QUOTE (haikii @ Feb 5 2008, 07:09 PM) </div>don't forget the reverse plugs on the gearbox. They may have fallen off maybe O_o
    Right near the bell housing on TOP of the transmission, you will find a "switch". Those break quite often.
    Also a sneaky point to trip you up is that not only is there a switch, but there is also a ballbearing which presses the switch.
    I was troubleshooting the same problem once. Pulled switch, pressed it, it worked, so I thought it was fine. But the ballbearing was missing so that when installed the switch was never pressed.
    Jan 2007
    LMFAO i have been scratching my head for the last 3 days trying to figure this out...
    okay cool ill check that out. how do i access that 'switch'
    can i just rip out that shit thing covering my gear shifter and look under it
    or do i have to get under the car
    are the plugs same as the switch that us_ae86 is talking about? lol i hope so
    thanks alot guys!
    Benn
    gold coast
    nope, you're gettin under the car mate, grab a multimeter or a test light and a helper(someone to slip it in and out of revearse while you're under it checking) GL
    May 2010
    total bitch to get to, if you can't get under there with a multi
    OR can't get access via your gearstick console...
    then you'll have to disconnect your tailshaft...and your bellhousing from the block...and lower it down and fiddle round.
    my t50 20 spline one was pretty r00ted when i looked at it, still worked tho..
    check your 'lamp' fuse too.
    /T
  1. T50 reverse light switch.
    By bradae85 in forum Technical - Questions
    Last Post: 27th August 2012, 09:30 PM
  2. Reverse light wiring
    By odessy in forum Technical - Questions
    Last Post: 26th August 2011, 10:10 AM
  3. T50 reverse light switch
    By ChrisGT in forum Cars or Parts Wanted
    Last Post: 23rd December 2007, 09:36 PM
  4. Reverse light switch from t50
    By slidn70 in forum Cars or Parts Wanted
    Last Post: 22nd August 2007, 06:39 PM
  5. REVERSE LIGHT NOT WORKING
    By Eddy in forum Technical - Questions
    Last Post: 12th July 2007, 02:19 AM
