Results 1 to 5 of 5
Thread: Yet another Diff question.. :) PLS help
    Senior Member Sturgey's Avatar
    Jarrod
    Launceston
    Cool
    Righto,
    Since ive just smashed yet another axle and centre and the keto isnt going,
    Ive pretty much read the entire tech section on here!
    Now my question is.
    I have been running a locked s series (b/w) in various ratio's from 3.9 to 4.3 but am sick of smashing the rear... so
    Will a T series complete rear axle bolt straight into a ke70.
    i understand the 4 link mounts are all the same, BUT what about the tailshaft/diff yoke?
    Does the s series tailshaft go straight up to the t-series? (ive got a custom 1 piece tailshaft that goes for my s13 g/box to s-series)
    How much bigger/stronger is the t over the s?
    Thats the main question i want answered, as its my nearest and cheapest option for getting my keto goin again, but if you guys are feeling "knowledgable" then is there a easy answer to this.....
    Is there any complete diff that will bolt straight in that is stronger than what I'm running.
    i'd love a hilux, but i don't wanna start shortning diffs etc
    Track can be increased, as ive increased track on the front.
    But any bolt in fit, tarago,celica,r31 etc... I'm not fussed
    please tell me what will fit with the most minimal of hassle.
    Thanks for ur time to read this, and thx in advance for your replies!
    Sly
    1984 ae71 Panelvan - Sold
    2000 Lexus IS200 - Cruiser
    Dave
    do a bit of searching around but:--->
    yes yes it will
    you need a rear T18 tail shaft section
    no, read above
    i don't exactly know, but i know they don't hold up to well to turbo applications, or even gze's.
    pretty much no other diff will bolt in at all, hilux etc is all custom, it has been done a few times and can be done relatively cheaply (1000$ or so, withouth LSD) but some are hard to get LSD for.
    plenty of info around!
    - Blaise Pascal
    Senior Member sly1300's Avatar
    Dan
    NorthEast
    <div class='quotetop'>QUOTE (ke70dave @ Feb 7 2008, 11:14 AM) </div>thx for ur fast reply, and yes. i have done a fair bit of reading on here. its all a bit g-series this, ma61 that.. bit confusing and i couldnt find and answer to why s series/t series tailshafts not fitting.
    is the bolt pattern for the t series "nose" of the diff the same as the s series. ie will my custom 1 piece tailshaft physically bolt to a t series, regardless of length.
    or should i not bother with a t series... just save my cash for a hilux conversion, and continue to stock up on axles and centres.. lol
    T and S diffs use the same bolt pattern on the front of the flange.
    But it sounds like you are running an SR20. I'd suggest skipping a T series diff and going straight to F or G or something else fat.
    Senior Member crackett's Avatar
    save your money, go an F or G series. you will blow up a T series again, i understand your running about 180killerwasps at the wheels right?
    spend a grand or so on a good conversion, will be worth it.
  1. diff question?
    By Drift_Donkey in forum Technical - Questions
    Last Post: 18th October 2010, 01:11 PM
  2. Diff Question??
    By GOODY in forum Technical - Questions
    Last Post: 3rd June 2009, 07:17 PM
  3. diff question
    By Akury in forum Technical - Questions
    Last Post: 25th March 2007, 11:42 AM
  4. diff question
    By driftke70 in forum General Topics (No Technical Questions)
    Last Post: 23rd July 2006, 09:51 PM
  5. Diff Question
    By crackett in forum Technical - Questions
    Last Post: 5th May 2006, 02:13 AM
