Results 1 to 10 of 10
Thread: Cutting Springs Tech
    Veteran DRFTPG's Avatar
    ADAM
    I always though springs go a tad harder when you cut them?
    but a friend of mine was saying they go softer?
    who is right?
    and I'm talking about cutting them with a cutting disk none of this heating up shit!!
    Veteran johl's Avatar
    Johl
    not again.....
    Jonathan
    This is the formula for spring stiffness:
    K = (W^4 x 12000000) / (8ND^3)
    K = spring stiffness in lb/inch
    W = wire diameter in inches
    N = number of active coils
    D = coil diameter in inches
    N is the number of coils. From the formula you can see, as N decreases K increases.
    So the answer is, springs get harder as you cut them shorter.
    BUT not that much harder.
    Great responce Jonny. Just one question: what is ^. Sorry for my ignorance.
    Anthony
    raised to.. power of. 2^3 is 2 cubed or and 4^2 is 4 squared
    Jonathan
    K = (W<sup>4</sup> x 12000000) / (8ND<sup>3</sup>)
    I just realised in this modern age I have a superscript button.
    12,000,000 is the torsional modulus of steel, which is listed as 11,250,000 in other places. Depends on what steel your using.
    Jase
    South Australia
    Glenelg
    Genius
    Member ronin_SPL's Avatar
    Apr 2010
    chaiyapol
    bangkok
    Bangkok
    Thailand
    They do get a bit harder and bounce a lot, don't be cheap and buy proper ones. :lol:
    Anthony
    <div class='quotetop'>QUOTE (4a-cnt @ Feb 9 2008, 09:21 PM) </div>Thats what your shocks are for. Nothing wrong with cutting springs if you think about what you're doing.
    gunbz-r
    ^^^ problem is not many people do, they just start cuttin, then wonder why the car high side when they turn hard, cut springs are stupid, and people will realise that when they lose a mate cause they told em to cut their springs.
    yes there is a way to do it but its not right, don't be a tight ass.
    There is a reason it is illegal and that is because it is stupid, dangerous and damn right ignorant, risk someones life for the sake of a couple hundred bucks, no offence but if u do it or have done it ur a fucking idiot.
  1. Spring cutting?
    By x744 in forum Sydney & NSW Events and Discussion
    Last Post: 22nd July 2012, 12:51 AM
  2. 4ac cutting out
    By khai2298 in forum Brisbane & QLD Events and Discussion
    Last Post: 23rd March 2011, 11:31 PM
  3. cutting front springs ke70
    By Ke70alex in forum Technical - Questions
    Last Post: 7th March 2010, 10:16 AM
  4. cutting down shifter
    Last Post: 6th May 2008, 01:25 AM
  5. What you get for cutting the apex
    By gumbie in forum Toyotas in the Media
    Last Post: 9th October 2005, 07:58 PM
