Results 1 to 10 of 10
Thread: 86 blowing smoke?
    Jun 2007
    hi my 86 blowing white smoke constantly? what can be the possible cause? could it be coolant leaking? time to change my head gasket???
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    sounds like ur rings man same problem as mine
    Jun 2007
    <div class='quotetop'>QUOTE (fozz @ Feb 11 2008, 04:27 PM) </div>but isnt ring blue smoke?
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Does the smoke sort of look like steam? If so then it is most likley time to change your head gasket and maybe get the head refaced and pressure tested
    gunbz-r
    the colour of oil smoke varies on tempreture, perform a comp test then a leak down test and u will end up with a result.
    does the amount of smoke become mre when driving harder?
    Sep 2006
    i got the same problem.
    white blue smoke and water blow out the exh pipe when engine is on, more comes out when higher rev.
    does this indicate bad rings?
    haven't done a compression test yet.
    also found some oil on the spark plug when i took them out.
    could this causing by old valve stem seals, thus leaking oil into the combustion chamber?
    other than this, is there any chance that the oil leaks from somewhere else of the head above into the chamber?
    it is better not the rings...
    any1?
    Member ronin_SPL's Avatar
    Apr 2010
    chaiyapol
    bangkok
    Bangkok
    Thailand
    Yes it is possible for oil to be leaking from you're valve stem seals they are alot easier to change than you're rings its a very common problem for smoky engines.
    May 2010
    Keffen
    Boxhill
    check oil pressure first then do a compression test, it could be as simple as no pressure for the oil.
    i could be wrong
    Aaron
    Vic
    Ballarat
    <div class='quotetop'>QUOTE (yuk86 @ May 2 2008, 08:32 PM) </div>If you had "no pressure for the oil." you would have more problems than just some smoke out of the exhaust!
    put 40w/70 hpr 50 in and see how you go
    thats what i run on my 4ac
    after idling for a while and drive off and a plume of blue smoke comes out thats valve stem seal
    if it comes out always and even more so when you thrash it, its either SUPER fucked valve stem seals or more than likely rings r shot
    if you have yuk86 mentioned LOW oil pressure liek when from idling and then lifting off then smoek will come out also
    putting in a thicker grade mineral oil will not only increase overall oil pressure, it will bleed slower from the rings and stem seals giving you less oil loss and yes, less smoke too
  1. my new 4agte blowing lots of white smoke
    By Nic19 in forum Technical - Questions
    Last Post: 14th December 2009, 06:46 AM
  2. 4agte turbo blowing smoke..
    Last Post: 9th February 2009, 10:12 PM
  3. 4AGZE blowing smoke
    By jamekins in forum Technical - Questions
    Last Post: 10th January 2009, 02:25 AM
  4. 4age blowing black smoke
    By deanoo in forum Technical - Questions
    Last Post: 19th January 2007, 07:01 PM
