Results 1 to 5 of 5
Thread: engine rebuild question
    Member SR_andy's Avatar
    Andrew
    Heritage park
    Default engine rebuild question
    ok so i have a 4age small port i am about to rebuild
    question is can anyone see any problems with what my plans are.
    small port 4age ( already have)
    ae101 quads ( already have)
    288, 8.5mm lift toda cams ( need to purchase)
    cam gears (already have)
    valve springs ( need to purchase)
    0.5 mm head gasket (need to purchase)
    extractors (already have)
    then just a basically rebuild the engine with new bearing, vrs kit, head studs and rod bolts.
    can anyone see any problems with the build at all.
    any input would be great
    Moderator Sam-Q's Avatar
    Endeavour Hills
    some local grind cams might do the exact same thing but cost you a heap less. Stock valve springs might be fine, I dont know
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Nothing wrong with that.
    Are you gonna wash all the parts and machine the deck of the block and head and linish crank?
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    yeah camtech sell good cams for 600 brand new, worth looking into if you dont mind it not being jap
    Andrew
    Heritage park
    camtech ey. might be worth looking into. the bugdet just blew out a bit as a truck cleaned up my sprinter and i am waiting to see how much the pay out figure is.
  1. 4AGZE Engine Rebuild
    By LiTTLe_DRaGoN_HuNTeR in forum Technical - Questions
    Last Post: 8th March 2008, 03:53 PM
  2. Engine rebuild
    By unit101 in forum Technical - Questions
    Last Post: 24th April 2007, 06:28 PM
  3. engine rebuild
    By psi_72 in forum Technical - Questions
    Last Post: 21st September 2006, 07:44 PM
  4. Cost of engine rebuild?
    By Skin in forum Technical - Questions
    Last Post: 25th March 2006, 04:20 PM
  5. Engine Rebuild
    By Shahzan in forum Technical - Questions
    Last Post: 4th December 2005, 12:55 PM
