Results 1 to 6 of 6
Thread: help needed to removing glass for hatch
    Oldschool Member
    Apr 2007
    hi, i need help removing the glass for the rear hatch. i tried and failed because i was scared to crack the glass. can someone give me some instructions on how to remove it. thanks alot
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Every other rear window I've ever pulled out you give it a boot from the inside out. This failed once, cause the rear window was sikaflexed in extremely hardcore and smashed into tiny pieces all over me.
    Mike
    Hahaha
    yeh, they should just push out with abit of effort, they are only held in by the rubber
    Oldschool Member
    Apr 2007
    so shear force will pop them out?
    Mike
    Ah,,, not like a sudden force,
    just gradual pressure, and someone on the otherside to hold it
    Senior Member Paw-DK's Avatar
    Mar 2010
    Paw
    Denmark
    General Area
    Christensen
    DUMA don't even ask your mate lol
    well rear hatch is held by a rubber.. all you need to get it out is a single hook (kinda like an L shape tool so it can get into the rubber)
    just start hooking the rubbers lip from the inside of the window from either side of the top edges putting constant pressure starting from one corner
    once you get the corner loose keep lipping around the rubber part that is loose all the way to until the top and both side is hanging out and it should pop up nicely from the bottom THUMBSUP
    and if there was originally sikaflex or polyurethane on the screen just check by using the hook to lip the outer side of the rubber (only to protect it from water leaks if the rubber wasnt giving a fully tight seal)
    hope that helps broo
  1. qld. hatch, dont need latches or glass, just the steel hatch
    By stefan in forum Cars or Parts Wanted
    Last Post: 10th April 2011, 07:12 PM
  2. Removing quarter glass and plastics?
    By stefan in forum Technical - Questions
    Last Post: 7th April 2011, 11:09 AM
  3. 86 HATCH WITH GLASS S.A
    By nos_86 in forum Car Parts For Sale
    Last Post: 29th June 2008, 04:45 PM
  4. removing headlight glass
    By loc33e in forum Technical - Questions
    Last Post: 25th September 2007, 11:20 PM
  5. removing hatch glass
    By Klutch in forum Technical - Questions
    Last Post: 24th August 2006, 01:00 AM
