<div class='quotetop'>QUOTE (wozza @ Feb 15 2008, 11:03 AM) </div>have you put 12v to the clutch?? should be two wires coming out of it, try that and it should click, otherwise, supposedly a commodore ac pulley works on them supposedly
Hey guys I've just bought a AE101 half cut with a faulty supercharger that I plan to put it into my AE86. I am unsure what is wrong with mine all I have been told in that its not engaging properly, does anyone know how fixable these things are.. common faults ect?
I am looking for SC12 and also any parts that would make it easier for me to install in a RWD configuration.
I'm in Melton, Victoria, will pick up anywhere in Melbourne Metro area.
<div class='quotetop'>QUOTE (dustyae86 @ Feb 15 2008, 11:14 AM) </div>Nope haven't even received my engine yet, let alone put it in the car.
I guess I was kind of hoping that someone had a charger with the pluming and/or brackets required for the ae86 4agze conversion to save me the messing around.
with the plumbing, the outlet is turned around the other way and thats about it, thne jsut need to get cooler piping, their a bit thin on the ground usually, and expensive so i would check it before replacing it
