Results 1 to 10 of 11
Thread: sr20 with a supra 5 speed ????
    Oldschool Member
    Feb 2008
    Guys i have a question ... does anyone know anyone who has put a supra 5 speed behind an sr20 ... i have just blown my sr20 5 speed and have been told that its very common as the box isnt very strong ... i was thinking of putting in a supra 5 speed as i know they are very strong.
    Any information or alternatives will all be greatly appreciated .... the sr20 is in my spriner :greenbounce:
    thanks in advance
    Veteran slide86's Avatar
    Huw
    Hills
    retain the sr20 bellhousing and get an RB box and bolt it onto the SR bellhousing.
    you will need a custom bellhousing to fit a supra box on an SR
    Oldschool Member
    Jul 2007
    What exactly blew in the box?
    Oldschool Member
    Feb 2006
    Which supra box?
    If you're talking W-box, meh, RB boxes cheap, plentiful alternative.
    If you're talking R154, the strength thing is all hype, may as well go RB25 or Z32 box.
    Benn
    gold coast
    not point in fitting a RB20det box to an sr, it isn't any stronger the the SR box
    rb25det and vg30 gearbox is alot stronger and is a common upgrade for high powerd SR's but it isn't a bolt up job.
    you'll need your sr front case/bellhousing and a RB25det box and find someone with a jig to cut and weld it up.
    Brendo
    rb20 g/box on and sr20 in a ke70/ae86 lines straight up with the shifter position or so ive heard, thats why people do it...
    Oldschool Member
    Feb 2008
    <div class='quotetop'>QUOTE (Brendo @ Feb 17 2008, 04:53 PM) </div>
    so to fit an rb25 box i will need to make a custom bell housing then .?? so essentially its no easier to fit than say a supra 5 speed as thats what i would need to do as well ..??
    hmmm surely someone is making something to put behind the sr's ... !! this is the first box ive blown in this car and i only ust bought it not long ago so who knows what paunishment it got before me .... but i know if i out another sr box in it wont take long before i blow another one..... what to do
    Oldschool Member
    Feb 2006
    Well the bellhousings and such for RB25 box behind SR are already available. As are ones for the Z32 box. I have no idea about shifter position.
    RB20 box has double synchros on the lower gears, unlike SR box, but yes is a fairly standard 71C box as used in practically every medium performance rwd Nissan from about 1978-late 90s.
    Advantage is of course that they are cheap as chips and easily available.
    I believe that the Nissan boxes would just be a simpler path than Toyota box to Nissan engine.
    Also unrelated example but wtnessed a fresh R154 last 2 meetings behind an RB30ET, RB25 box has lasted 2 seasons since.
    Ty
    ACT
    ACT
    Oldschool Member
    Feb 2008
    <div class='quotetop'>QUOTE (floody31 @ Feb 17 2008, 08:19 PM) </div>Do you know how makes the bell housing for the rb25 to an sr .?? this is going in my sprinter is the box physically bigger as well .?? as in will i have to modify any tunnels or anything like that ??
    Whats an rb25 box worth roughly and where is the best place to source one .??
  1. '96 Toyota Supra 5- Speed manual
    By Rob574 in forum Cars for Sale (Toyota Only)
    Last Post: 26th March 2010, 02:25 PM
  2. Supra 5 speed tailshaft
    By reecegze in forum Cars or Parts Wanted
    Last Post: 3rd June 2008, 10:50 PM
  3. WTB - SUPRA 5 SPEED
    By syco86 in forum Cars or Parts Wanted
    Last Post: 20th February 2008, 02:33 PM
  4. old skool supra 5 speed onto a 16v ?
    By mtgg85 in forum Technical - Questions
    Last Post: 11th December 2005, 04:37 PM
