Results 1 to 10 of 19
Thread: water injection with quad throttle bodies
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    Post
    hi all i am seriously considering doing water injection on my silvertop 20v
    want to know how i'd go about it and has anyone here had past experiences with water injection whether it be with quads or not any engne really but would like to find how i'd go about using it on a 20v
    please discuss
    MY JZX83 (clicky)
    gunbz-r
    may i ask why u want to go on such an adventure?
    Brendan
    NORTHSIDE YO
    I'm an adventurous kind of guy, what can i say
    MY JZX83 (clicky)
    gunbz-r
    as long as its not to combat pingin, its alright. man methanol injection, if u wanna get adventurous.
    i always had an idea of using a sort of direct port gas set up, usin the solenoids and jets so it can be accurately tuned, with a 2l alloy tank stashed somewhere, injection pump up to a solenoid then a common block to run the lines str8 into the throttles, and triggered at full throttle like a conventional gas set up
    tho its always just been an idea, and probably always will be lol
    Brendan
    NORTHSIDE YO
    yeah
    i have been reading up a bit about it, i'd just like to see if anyone has had experiences with it
    from what ive read and seen water injection will make your engine incrase power which is caused by the water atomising when sucked into the intake which would in theory would create a kind of "boost" and with the water it keeps the pistons and bore at an even temp to prevent "hot spots" etc
    i would like to know more as with me running a microtech i can set it up to run off an auzhilary port on the ecu which i can choose to "kick in" at a certain TPS angle, RPM or even engine temp(engine temp is pointless) but yeah
    just toying with the idea at the moment but very keen to do it and have the cash to do so as from what i have read the kits arent overly expensive so yeah
    please discuss experiences and please let me know if there is anything i have missed apart from the fact it would be illegal as it would effect emissions but that doesnt worry me
    MY JZX83 (clicky)
    gunbz-r
    well the only hang up i'd have with running it of an auxilary out, is that its always going to work unless the system is disarmed. where with havng it triggered of the throttle, u can have it armed and still drive it hard without it actually coming on. (as long as u don't get to full throttle)
    what u have said about the kind of boost effect is tru from what i hav been told, the way it was explained to me was it ups ur compression ratio as the water has no true burning properties in its given state. but thats why i'd prefer methanol injection, it has the same charicteristics of water once in the chamber in terms of cooling (probably better) but it burns and burns quite aggresivley.
    tho i don't kno much more than that, but i trust what i have said as it was told to me by someone that knows their shit.
    I'm guessin ur lookin at the kits vpw sell? i'd like to kno what happens when fitted to a 20v.
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    Apparently a 50/50 mix of methanol and water is the way to go. Basically the water will increase the compression (water being incompressible) in the cylinders by taking up volume. But with increased compression the chances of knocking is also greater, which is where the methanol comes in. With a much higher octane than petrol it should resist any pinging from the extra compression and allow your knock sensor to run the engine at max advance and hence max power. I really doubt the tiny amount of methanol injected would help with anything other than reducing the chance of knocking, as it takes something like 2.5 times the amount of methanol to create the same amount of power as petrol.
    gunbz-r
    ^^^true, i forgot that part, for those that don't know thats why u see methanol drag cars with twice as many injectors.
    and i have heard of the 50 50 mix, and i believe thats what most people use, but as i said i haven't had any experience so i can't really comment any further.
    i might do some research today
    Injecting water will not change the compression ratio. Water is incompressible as a fluid, but once you boil it (inside your combustion chamber it'll get to over 100deg) it turns to steam which is compressible.
    One use of water injection is that boiling the water takes a lot of energy, so as the charge is compressed and gets hot, some of the heat is used to boil the water, hence the charge stays a bit cooler. Cooler=less likely to ping, etc...
    gunbz-r
    ah yeah, and from that u can dick with the timing or boost, without it pinging hence the extra power.
  1. 4age quad throttle bodies.
    By hughesy666 in forum Cars or Parts Wanted
    Last Post: 17th October 2012, 09:10 PM
  2. quad throttle bodies on 4agte
    By _wanna-be_ in forum Technical - Questions
    Last Post: 19th March 2012, 10:14 PM
  3. 20V Quad Throttle Bodies
    By race4ages in forum Car Parts For Sale
    Last Post: 26th August 2009, 07:23 PM
  4. quad throttle bodies
    By Cerby in forum Technical - Questions
    Last Post: 24th January 2007, 10:49 PM
