Results 1 to 7 of 7
Thread: 20v TPS adjustment
    Veteran driftism's Avatar
    Andrew
    Watsoia
    EDIT:
    now need advice on adjusting my tps so it works properly
    Thanks
    Need a TPS plug for the TPS on my throttle bodies
    I have a TPS from a Bigport 4age (mr2) and the plug is the same as the 20v one, which got me thinking... are there any other models of car that have the same plug as the 20v? such as a newer model toyota? I have a 1jz loom at home and i am thinking there might be one on there...
    I need one to suit, so if someone knows a part no. or has any other info on what to get one off, that would be great.
    or if someone has one they wanna sell me that would be better
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    i think your out of luck finding another the same, blacktop 20v tps plug wont even fit as i had a BT loom and tested it on my ST switch and did not fit
    need to finda ST 20v one mate, sorry i can't help but yeah that should solve your queries
    MY JZX83 (clicky)
    Elite rthy's Avatar
    Leo
    Tulla
    can you buy just the plug from Toyota officially?
    Andrew
    Watsoia
    you can, but it will probably end up costing a lot more than one from a wreckers if a match can be found.
    ... i've found that there are 3 of the same plugs on a 1jz loom, the wiring colours are obviously different, but they clip up fine.
    now i am having a lot of trouble setting it up, does anyone know of a site or walkthough of this? the one that is in tech articles currently is not very helpful, and I'm not sure that the tps settings will be the same for them anyway (between 16 and 20v)
    Elite rthy's Avatar
    Leo
    Tulla
    second post
    Andrew
    Watsoia
    exactly what i needed to see...
    Thanks heaps
    Elite rthy's Avatar
    Leo
    Tulla
    sure thing
  1. TPS Adjustment
    By TruenoCoupe in forum Technical - Articles
    Last Post: 28th July 2008, 01:03 PM
  2. WTB: 20v wiring loom or 20v injector, VVT & TPS plugs
    By HYPNTK in forum Cars or Parts Wanted
    Last Post: 13th March 2007, 09:20 PM
