1/ 3SGE Race engine, previouslly dynoed with 150 rw HP
GEN II engine.
Big cams, ported and polished, extra oil drain back holes for head. Shim over style head with shims secured to buckets.
High compression bottom end.
Comes with trap door style sump setup - reduces oil surge
Engine oil breather tank.
Engine dissasembled but comes with new gaskets, new rings and bearings. Bottom end has been covered in grease to preserve condition.
The engine is not complete there may be a few fittings etc that it is needed. I do not know what parts are needed, but all major components are included.
Many $'s spent on engine, But i have too many of them now. This one has to go.
$1000
2/ Here is a W series Supra 5 speed gearbox. It is exactly the same as my w57 box but has an aluminium sandwich plate.
Bell housing suits 3sge
It has been setup with an integral clutch slave cylinder.
as far as i know box is in good condition.
comes with cross member to suit A86 or KE70 etc.
Will try to locate a front tailshaft yoke for you as well.
$500
Happy to freight Australia wide.
Inspections welcome at Ballina NSW 2478
Cheers Jason Clements
0414 482320
