Results 1 to 8 of 8
Thread: TVIS question.
    Senior Member shinny's Avatar
    Liam
    hey,
    i've got the tvis out of the car coz it wasn't working.
    the little vacuum inlet was blocked so i've cleaned that out, and replaced the hoses.
    i was just wondering if anyone knows if the TVIS wiring plug has 12v in "on" on the ignition??
    and can you bypass the vacuum canister, to have the actuator diaphram straight to the inlet manifold without dramas's??
    Veteran driftism's Avatar
    Andrew
    Watsoia
    i'd test the plug with a test light to see if it has power or not.
    not sure about the vacuum canister, but why would you want to disconnect it?
    Liam
    <div class='quotetop'>QUOTE (4AGE - 86 @ Feb 25 2008, 07:54 PM) </div>no i don't want to disconnect it at all,
    the reason was i checked the plug and had no voltage with the ignition at "on" position,
    so i've bypassed the canister scared that i didn't have power to the solenoid,
    the TVIS butterfly actuator goes straight to vacuum now,
    all works sweet now,
    cheers for the reply andy,
    Andrew
    Watsoia
    it wouldn't have any voltage at the on position, because it would be off until TVIS was activated, then it should have power.
    doesn't really matter if it is working now though
    Oldschool Member
    Dec 2006
    Glen
    You want the vacumm can thingo --- or i suppose the buttiflies might close at high rpm due to lack of vac, or close to 0 anyways..... I took tvis off completly.
    Glen
    Liam
    <div class='quotetop'>QUOTE (Jazz9 @ Feb 26 2008, 10:10 PM) </div>the butterflys are open at their rest position,
    they use the manifold vacuum to close in the bottom half of the rev range,
    the reason i want it working is coz it's a pig to drive with it disconnected you go no where under 3,000rpm,
    that and you loose a significant amount of torque without them working,
    Andrew
    Watsoia
    and it uses lots of fuel as well...
    Mar 2011
    lewis
    nsw
    hills district
    Where does the blue plug plug into????
    the tvis butterfly has the vacuum actuator and surge tank part but needs to be plugged into a blue plug can u help me out?
    <div class='quotetop'>QUOTE (shinny @ Feb 28 2008, 05:48 PM) </div>
  1. TVIS question.... Do I need it? 4age with Microtech
    By maxhag in forum Technical - Questions
    Last Post: 28th August 2011, 11:49 AM
  2. tvis or no tvis
    By johl in forum Technical - Questions
    Last Post: 7th October 2010, 11:52 PM
  3. 7age use TVIS ?
    By sun_moon in forum Technical - Questions
    Last Post: 6th June 2009, 12:11 AM
  4. TVIS BUTTERFLIES
    By lewy in forum Cars or Parts Wanted
    Last Post: 23rd January 2008, 08:17 AM
  5. tvis problems
    By lewy in forum Technical - Questions
    Last Post: 13th January 2008, 04:25 PM
