I have a 1984 Toyota Corolla AE71 with a S13 sr20 na turbo in it.
located in Sylvania, Sydney
The car is in good condition for a car of its age
Asking $9,000
ENGINE - SR20de with stainless exhaust manifold and s14 t28 bush bearing turbo. Braided oil and water lines, custom aluminium intercooler piping, front mount intercooler. New clutch master and slave cylinders. New water pump. Engine stabilizer. New battery
Recored radiator with 11inch thermo fan.
Heavy duty clutch.
EXHAUST - 3 inch mandrel bent mild steel exhaust.
ECU - Haltech E6X, ls1 coil, standard s13 sr20det injectors, electronic boost controller.
FUEL SYSTEM - Facet lifter pump, walbro external fuel pump and surge tank. New fuel lines, filters and clamps.
SUSPENSION/BRAKES - New front shocks, standard cut springs, standard sway bars, standard brakes with new front brake hoses, rear shoes and wheels cylinders. Standard Locker rear diff.
WHEELS - 15 x 6.5 inch performance alloy wheels wrapped in 195/50r15 tyres with good rubber and spare tyres. Same wheel in spare too. 25mm bolt on spaces on front.
INTERIOR - The inside is standard and fairly neat. Only a Blitz boost gauge has been added to the interior of the car.
The car has 128,000 kms on it and the engine was out of a s13 with 105,000 kms on the clock. The car also comes with 12 months rego New oils, fluids, plugs and filters throughout the car.
Made 145kw at the wheels on 11psi
Contact Grant on 0412 170 266
[attachment=23006:IMG_0276.JPG]
[attachment=23007:IMG_0281.JPG]
[attachment=23008:IMG_0280.JPG]
