Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: sr20de ke70
    Seth
    hi fella's,
    up for grabs is a 1983 flat nose ke70 with a s13 sr20de motor with manual box installed.
    engine has new pilot bearing
    new front crankshaft seal
    new flywheel bolts
    there's lots to do to finish it, this is what it comes with:
    ecu/loom
    big arse landcruiser radiator (pressure tested and painted, 4core!!)
    nicely painted stock dash (now black)
    ae86 front struts
    JDM calipers and a rebuild kit to go with
    brand new JDM discs to suit
    brand new brake and clutch master cylinders
    hydrualic pedal box
    set of 4 king springs
    revolver NCRA's
    s-series diff (was installed before i got it.
    set of 4 14x7 -3 offsett work equip 01's no tyres but with centre caps!
    bad points:
    cracked windscreen
    unfinished body work (sanding)
    no front seats (just rails)
    you have to tow it away.
    pics can be found in my members ride:
    $3000
    toowoomba , QLD.
    Veteran biggo's Avatar
    Nick
    Noosa
    Interested!
    What is the shell like? All I'm really interested in but yair shell? Rust? Dints? etc etc
    Seth
    i slight dent on rear panel (hardly noticable)
    a little rust on one rear wheel arch, already semi welded up (the size of 2 20 cent pieces)
    oh and one of the front quarter panels had a kink in it but i've almost fixed it
    i bought this shell especially cause of the lack of rust!
    Seth
    its splitt'n time!
    1.sr20 with box/loom/ecu - $1000 - pickup
    2.ae86 front struts with hubs - $100 - pickup
    3.JDM calipers and a rebuild kit to go with - 260 - will post
    4.brand new JDM discs to suit - 100 - will post
    5.new brake master cylinder - 120 - will post
    6.new clutch master cylinder - 50 - will post
    7.hydrualic pedal box - 50 - will post
    8.set of 4 ae86 king springs - 120 - will post
    9.used revolver NCRA's - 80 - will post
    10.set of 4 14x7 -3 offsett work equip 01's no tyres but with centre caps! - 800 - pick up.
    :2thumbs:
    Senior Member hilux05's Avatar
    Rich
    Sunshine Coast
    pmeded
    Jan 2008
    havue u got engine n gearbox mounts??
    Seth
    yup, although you'd kinda need the crossmember as part of the engines mounts........
    Oldschool Member
    Dec 2006
    Does the sr come with the mounts included in the price?
    Seth
    yup, (what are you upto?)
    $1000 for SR20DE, gearbox, loom, ecu, crossmembers to suit *E7* and mounts?
    that is a MASSIVE bargain!!!
    If you were in Adelaide, this would be SO sold!!
    I know it says pickup only, but how much to freight/courier/post/whatever to adelaide?
    Oh and just as a comparison, Adeaide Jap are selling just the SR20DE for $950 :blink:
  1. SR20DE+T KE70 in the buildzzz
    By Simon-KE70 in forum KE70 / AE71 Owners Forums
    Last Post: 7th August 2009, 08:26 PM
  2. sr20de in ke70.
    By Nic19 in forum Technical - Questions
    Last Post: 31st August 2008, 12:12 AM
  3. sr20de ke70 gear
    By japlish in forum Car Parts For Sale
    Last Post: 7th April 2008, 11:42 AM
