Results 1 to 10 of 10
Thread: pinion angle
    like the title said how many degrees should it be angled
    at to get the best traction to the ground for racing
    Dave
    I'm no expert on the adjustable 4-link setup
    but i am under the impression that the optimum angle will change alot with individual car setup
    so there is no precise measurement that is the "best"
    stuff like spring rate, sway bars, condition of bushes, tyre choice (profile etc) will all have an effect on where the "optimum" position for your diff is
    i think the best way to go about it, is experimentation with your specific setup
    - Blaise Pascal
    r u sure i know alot makes sense with what you just said but surely theres a set angle
    that assist with the driveline putting power to the ground?
    Elite rthy's Avatar
    Leo
    Tulla
    too many factors, only trial and error is the sure fire way.
    I would try starting between 3 to 6 deg , ( pinion nose down from factory spec ) , It all depends on how much give there is in the bushes ,
    Harry
    VICTORIA
    spread the word.... pinion angle does not change the amount of traction u get. it only fucks uni joints quicker
    what changes traction characteristics is.... if u imagine a line from the top diff mounting points to the lower diff mounting points changing this angle makes a difference
    so by shortening or lengthening the upper/lower trailing arms u are actually changing this angle (and also the pinion angle but that doesnt change anything)
    Elite rthy's Avatar
    Leo
    Tulla
    oh interesting, so basicly your saying that people are thinking they are correcting pinion angle when in reality they are changing the anti-squat settings?
    Andrew
    Changing the lengths of the links does have an effect on the anti squat, but it will rat out the uni's and the effect is not enormous. This was discussed in another thread with pics of the roll centres etc for 4 link rears.
    Another issue, putting solid bushings eg rose jonts or urethane in all of the 4 link bush points creates a swaybar effect with the diff acting as a swaybar during roll. I'd draw it but i only have paint and its rubbish.
    Aug 2006
    putting softer springs and shocks in the rear will help gain you some traction along with other mods, it depends what you are doing, drag?, drift?.
    Elite rthy's Avatar
    Leo
    Tulla
    hey lets go back to the begining, are you running "traction brackets" ??
  1. DIY: a quick outline on why & how to set pinion angle.
    By assassin10000 in forum Technical - Articles
    Last Post: 10th December 2010, 09:53 PM
  2. crank angle angle
    By callum1 in forum Technical - Questions
    Last Post: 24th January 2010, 07:22 PM
  3. pinion angle
    By ae86=fun in forum Technical - Questions
    Last Post: 30th August 2008, 03:33 PM
  4. Best method to change diff Pinion angle?
    By eightsixboy in forum Technical - Questions
    Last Post: 27th May 2008, 09:38 PM
  5. got angle?
    By driftke70 in forum Toyotas in the Media
    Last Post: 22nd May 2007, 08:37 PM
