Results 1 to 10 of 11
Thread: which clutch to use in a ke70?
    Hey, thought id just edit my other thread so i woudlnt have to make another one
    my clutch in my ke70 is very much broken,
    could anyone recommend a good brand of clutch for my ke70
    id like it to be good, but not to heavy, i still want it easily driveable, its not a racecar afterall.
    i was thinking an xtreme clutch? are these any good? ive heard good things and ive heard bad things,
    also budget comes into play, id like to spend up to about 150 dollars
    -cheers
    Original Post:
    hey guys,
    I'm in the process of taking out my 4 spd from my ke70 to find out what is fucked (sumthin between flywheel and box I'm hopeing)
    and i was just wondering how i take the shifter out?
    i took the 4 small bolts taht sit around it out, what now?
    thx
    any information is apreciated on this and also tips of box removal
    -Alex
    done, it just puled out
    new problem,
    how do i disconnect the clutch cable from the gearbox?
    ive got it off the little hook (clutch fork?)
    but how do i get it back through the bellhouseing so i can take the gearbox off without the clutch cable still being attacthed to it?
    BUmp
    need help, need this box out 2nite
    how do i remove clutch cable form bellhousing?
    Veteran biggo's Avatar
    Nick
    Noosa
    completely undo the gbox side. you should eventrully beablr to sllide it out with some effort. its been awhile since i did it but thats what i rembmer
    it has like a lil rectangle thing on the end and a small boot, on the bellhousing side, how do i take this rectangle thing off so i cna slide the cable through?
    Heyhey, this is Archangel62 (Eli) posting for Grape_Moosha (Dmang).
    We're all done, we got the gbox out. The clutch cable was catching on shit at the pedal end so we thought it couldn't come out that way, but we got it in the end. From there it was pretty smooth sailing, we pryed the bellhousing out from the motor a bit and gave it a bit of a shake and it came off real easy.
    And the cluch is MAIMED!! I must say its a fair effort. the actual clutch plate snapped into three (main) pieces. Each gripping disc snapped off completely, and the fins that connected them to the metal centre are now millions of shards of metal. It's decent. He's prob gonna slam a heavy duty clutch in there and it'll all be sweet.
    CLutch is fucked lol
    Nick
    Noosa
    you shouldbe worried
    that is not a normal malfuction.
    Oldschool Member
    Oct 2007
    How long has this clutch been fucked for? lol.
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    Dude, put that clutch back in, it looks like a button clutch now!
    Hahaha
    On topic, a Exedy Heavy Duty would be the best clutch for your purpose
  1. ke70 clutch problem
    By bigm in forum Technical - Questions
    Last Post: 1st September 2008, 09:46 AM
  2. clutch cable for a ke70
    By Clinton in forum Cars or Parts Wanted
    Last Post: 12th August 2008, 07:01 PM
  3. Ke70 Clutch Kit
    By grape_moosha in forum Cars or Parts Wanted
    Last Post: 7th March 2008, 12:48 PM
  4. ke70 clutch
    By Sprinter_Seth in forum Technical - Questions
    Last Post: 29th May 2006, 11:02 PM
